Question about Nespresso Citizmilk C120
The milk in the frother won't foam. I tried different kinds of milk but still doesn't work
  • 155 Answers
The frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Posted on Sep 14, 2010
  • 1 more comment
  • xtacie85 Oct 21, 2010
    I tried to browse through different websites on how to 'fix' this problem with my nespresso machine and couldn't find the solution. My milk frother doesn't seem to be working properly as it only heats the milk, but does not seem to spin/froth it. I filled the bottom as accoridng to the mark or lower, and tried changing the 2 attachments and it still doesn't froth, just only heat the milk. Hope you can help with this. Thanks.!
  • kiaora1982 Feb 18, 2011
    I am having this exact problem and my machine is only a month old!!!
  • carebearsuzi Jun 18, 2011
    My machine is 3 months old. Same problem. Seems there is no way to fix it? All parts are clean, spinning etc. Ive used this same milk before and it worked fine.
My breville milk frother was submerged in water and won;t work, how can I fix it?
If it does not work after _thoroughly_ drying it out, then the circuit board went bad from turning it on while it was still wet.
Feb 26, 2015 | Breville Milk Cafe Automatic Milk Frother,...
My milk is no longer foaming! what gives?
Use fresh milk - skim or 1% actually works better than whole milk.
If that doesn't work, then your temperature is not getting high enough.
Jul 31, 2014 | Nespresso Aeroccino Automatic Milk Frother
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
How much is a Aeroccino Milk Frother
as of oct. 2nd 2010,amazon.com has them posted at $99.00
Oct 12, 2010 | Nespresso Aeroccino Automatic Milk Frother
It froth's milk beautifully but won't do soy milk.
We bought a Nespresso Milk Frother in 2010 for $100. The frother is the same one that comes with the Citiz machine but is a stand alone model. It froths soy milk very well. The less soy you put in it, the more froth you get but even if we fill it to the max line we still get a reasonable amount of foam. We use Silk brand soy milk. I have no idea if foaming is impacted by atmospheric pressure but it may be a factor to consider if you are using all the same factors as us but not getting great results. We live at a higher elevation Calgary, Canada in the foothills of the Rocky Mountains.
Sep 15, 2010 | Nespresso Aeroccino Automatic Milk Frother
Milk not frothing
It depends on the milk you use. I have this problem with certain brands of milk but with others, it froths very fluffy. I actually went as far as checking with a dairy and I was told it has something to do with the cow's performance on a particular day (slightly strange!) and the proportion of water mixed with full milk to make the semi-skimmed. For some bizarre reason, the supermarket own-brands milk work much better than the branded ones. I doubt there's anything wrong with your frother, just try a few different brands of milk until you find the right one!
Apr 20, 2010 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Steam wand used to make great foam until just a week ago
The stainless steel cover has a very small hole near the top. The hole allows a venturi action - meaning air molecules are entrained with the steam flow to increase the affect. Milk will clog the hole, but warm water and a guitar string, cheese wire, even a staple - something thin - will work to clean it out.
After frothing either clean the entire stainless steel piece or at least occlude the end at the same time as shooting through some steam. I usually use a kitchen sponge with the abrasive pad attached. The pad helps insulate the heat and provides the necessary resistance to force any milk out the small hole.
Yes, I hate living with this also. In fact I am considering machining a different steam tube assembly.
Red
Oct 05, 2007 | Saeco Incanto Rondo Fully Automatic Coffee...
Nespresso Citizmilk C120 Logo
1,329 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
