Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Code F7 on my GE Spectra XL44
I keep gettig code F7 and it will not clear. What should I do?
  • smirth Dec 28, 2008
    I am getting F7 (in red) and flashing Eb or E6 that wont clear on Spectra XL44.
  • choran07 Jan 06, 2009
    F7 in red flashing on stove of XL 44 GE Spectra
    Guru:
  • 93 Answers
Http://www.fixya.com/support/t120458-ge_profile_oven_ftp18_f7_code
Try reading this and see if it helps you any, thank you
Posted on May 16, 2008
Hi there - My GE Profile spectra XL44 Gas Stove shows code F1 with none-stop beeps, I only sgut the power off... - what should i do to kill that noise now ?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Sep 27, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
F1 and beep on my GE spectra oven XL44 what is that
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Aug 16, 2011 | GE Profile Spectra JGBP79 Gas Kitchen...
I have a GE Spectra Profile XL 44 and I get an code F0. What does that mean?
Here is a tip that I wrote that will help you with the Xl44 profile error codes.
Oven Fault Codes for GE XL44 Oven
heatman101
Oct 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE profile XL44 code F7 & FO readng on
Turn the circuit breaker off at the switchboard for a minute then back on again. This may reset the electronics.
Nov 22, 2009 | GE Kitchen Ranges
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
GE SPECTRA GAS RANGE XL 44 BEEPS AND DISPLAY F7
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont turn on and f7 keeps beeping, but stove top burners work on ge spectra xl44 on model number jgbp86bea3bb
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
Thanks
Mar 07, 2009 | General Electric Stove/Oven/Range Chrome...
JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
Control panel shows F7 and contantly alarming or beebing
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,948 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
