Question about Magic Chef MCBR170 Compact Refrigerator
Are there replacement plastic liners for a Magic Chef MCBR415S Compact Refrigerator? I need to replace the refrigerator section and the freezer door liners.
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
woodchuck789
  • 4070 Answers
SOURCE: Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Posted on Jul 09, 2009
  • 19 Answers
SOURCE: The freezer is working but the refrigerator is not
I have the same one. It was outside in the garage-brand new-had that same problem. We taped foam insulation on sides and parts of the back-that worked! We have since moved and now it is in the climate controlled basement and works fine w/o duct tape! get what you pay for huh?!
Posted on Sep 01, 2009
SOURCE: Loud buzzing noise on a Magic Chef compact refrigerator help!
Disconnect power from unit. Remove the cover at the bottom, rear. Examine all refrigerant tubing for contact with other tubing or other surface. Carefully adjust the tubing to prevent contact vibration.
Posted on Sep 12, 2009
heatman101
  • 43501 Answers
SOURCE: Hi. My Magic Chef refrigerator ctb1722arw is not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 12, 2011
I have a Magic Chef MCBR1000W. The recent east coast earthquake shook the freezer door open while I was away on vacation. When I returned three days later, the freezer compartment (open) and refrigerator...
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
Aug 28, 2011 | Magic Chef CTN1521 Top Freezer...
I have Magic Chef refrigerator model MCBR415S frezzer is working but the refrigerator only cools to 52 degress what can be the problem
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
Magic chef compact refrigerater stopped cooling compreser is warm to touch and is makeing clicking noise every few minutes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | Magic Chef MCBR445B2 (4.4 cu. ft.) Compact...
Sep 12, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chef MCBR415S cabinet get's very HOT!
* Is your compressor motor running all the time ?
* have you checked and cleaned your condenser coils at the back ?
* Is there sufficient airflow around your refrigerator (especially at the back) ?
* Is your refrigerator and freezer cooling properly ?
Sounds like your unit is working overtime - it will usually get hot like that when compressor motor has been running a long time and heat does not dissipate properly at the back - it also gets hot after a defrost cycle - it should NOT be hot at all times. CHeck to make sure your temps are correct to rule out a stuck defrost cycle timer - your refrigerator should not be hotter than 40F and your freezer's temp between 0F-10F, the optimal temp is 0F.
Aug 17, 2009 | Magic Chef Refrigerators
Aug 27, 2008 | Magic Chef Refrigerators
Magic Chef MCBR170 Compact Refrigerator Logo
53 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
