I have a set of Dell MMS 560 speakers. I just recently moved into an apartment from a house. Immediately upon setting up my computer at the new apartment, my main speaker (the one with the volume knob on it) is now picking up a local radio station, even when the computer itself is powered off. As long as the speaker itself is on, the noise comes through. Sometimes it's very faint with a lot of static, and sometimes it's very loud and clear. The radio tower is at least a couple miles away. The volume knob on the speaker does not affect the volume of the radio station, but if the speaker is all the way off, no sound is heard. I tried clipping a noise filter on the cord and it reduced the noise very slightly. I also plugged the speaker into a surge protector that is supposed to filter out this kind of noise. It didn't help at all. Is there any way to get rid of this noise?
  • 1 more comment
  • ricola83 Sep 15, 2010
    I have had these speakers for seven years. I briefly had this same problem a few years ago but it went away on its own. It seems much worse this time.
    Thanks for the info.
  • ricola83 Sep 16, 2010
    Thank you. You seem to know what you're talking about. I will probably not get a chance to test this out for a few days but I will let you know how it goes.
  • 905 Answers
For testing purposes, move the main speaker as close to the PC as you can. Roll the excess cable up into a tight circle. You are creating a "choke" and should help with the symptoms that you are having. If it sounds like the problem is diminishing, make note how the coil lays (flat or upright). Then turn it the other way, and note if it reduces the sound or not. If you get a noticeable improvement, then Radio Frequency Interference is being coupled via the input leads.
On the power lead, do the same thing. Move the speaking close to the power outlet, and roll the power cord into a tight circle. You should be able to hear a reduction in the noise. Make note of the position (flat, upright), and switch to the other position.
Whether it be the input lead, or the power lead, whichever one had the greatest effect is where a noise filter needs to go. Some electronic retailers (Radio Shack for example) sell filters that are designed to have the cord wrapped around and through. These are very effective. You will probably find that this type of filter will be needed on both the input as well as the power cord to the speaker system.
Another method of reducing the noise is to shield the cables. While they are coiled up in tight circles, try wrapping a small piece of aluminum foil around the circle. You should notice a drastic improvement if the signal is being coupled through the cables. Try the foil on both coils. If there is an improvement, then you might be able to use copper or aluminum braid as a shield. This method is expensive though, the braid is a bit pricy. To use it, you would feed the cable (one cable per braid) through the middle of the braid, and then ground the braid to the metal chassis of the computer. If noise is *still* getting in, then it is likely being coupled off the power line. A good quality AC noise filter designed for this purpose would be in order here. A local electronics shop may also be able to add on an inline noise filter to the power cable just before it connects to the speaker itself.
Post back your results, I enjoy noise issues, and have become pretty good at identifying source, and mitigating their effects.
Posted on Sep 15, 2010
  • 3,083 Answers
My first thought is that it's the nearby radio station, and there's little you can do about it without trying heavy shielded speaker wires. This blog talks about different situations, and some may work- I've never tried it:
http://www.techspot.com/vb/topic7677.html
If you use shorter speaker wires, that might also help, but would cut into the stereo separation, but shielded or shorter are the most likely solutions I see.
Good luck, and hope this helps.
    President:
  • 4,070 Answers
Hi! Have you tried using a different speaker? Try it for the current speaker may be prone to statics. Try using a different speaker and see how it goes. Hope this helps and thank you for using FixYa!
Posted on Sep 14, 2010
  • 1 more comment
  • dj_relly999
    dj_relly999 Sep 15, 2010
    Mostly this is caused by short circuitry or tripping capacitors.
  • dj_relly999
    Have a nice day!
  • dj_relly999
    dj_relly999 Sep 17, 2010
    Good luck on this!
I'M TRYING TO CONNECT MY MMS 321 PHILIPS COMPUTER SPEAKERS TO MY 32 in LG TV CAN YOU HELP ?
Hi Richard,
Connecting the speakers tot he LG Tv is fairly simple.. Connect the audio cable from the speakers to the headphone jack on the TV. The headphone jack will be either on the left or right side of your TV depending upon the model number.
I'm attaching the user manual for the speakers for your reference
Thanks for using Fixya
Proton
Mar 13, 2012 | Philips MMS 321 Computer Speakers
My inbuilt speakers are not working.
take a digital multimeter and check through ohms range if there r show continuting the speaker than u know that your speaker is ok
Apr 12, 2010 | Audio Players & Recorders
Samsung Tocco Lite MMS message sending problem
Steps to correct the MMS delivery time
1. Select Menu
2. Select Messages
3. Select Message settings
4. Select Picture Message
5. Select Sending options
6. Select Delivery
7. Select Immediately
8. Save the settings and retest sending MMS.
Mar 01, 2010 | Samsung Cell Phones
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Touchpad+ sound not working
maybe the built in speaker is set to minimum.
press and hold Fn key + Page up
or
go to system set up (F2 when u see the dell logo)
enable the speaker.
Mar 16, 2009 | Dell Inspiron 8100 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
