Question about GE Washing Machines
Washer wont rinse completely. some water remains in the washer.
The pump will be blocked, there is a kick plate at the front of the machine at the bottom, remove this then release the round filter, remove any debris, if theis doesn't work you will have to rvove the pipes/hoses from the pump to remove any debris, had same problem just done mine working fine now
Posted on May 15, 2008
Wont rinse
all washers rinse in cold water so clothes don't wrinkle,so if it won't rinse make sure your cold water is running
Apr 17, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I just had a Frigidaire front load washer installed today model #GLTF2940FS1 and I am having a problem with the rinse cycle. When the wash cycle is completed and the spin cycle the machine will stop at 26...
hi thanks for the question make sure both water taps to washer are on check that because if the cold water if off it wont go into rinse cycle thanks the appliance doc
Sep 27, 2008 | Frigidaire Washing Machines
Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Mar 29, 2008 | Washing Machines
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dishes and inside the washer are not drying
Make sure that the drain hose is connected as per manufacturer instructions, and that there isn't a direct run down from the sink u-bend to the machine. The rinse agent effects dishes dry but has nothing with the water remaining in the machine. Good luck!
Sep 15, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washing Machines Logo
27 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
