Question about GE (PSS26MSRSS) Side by Side Refrigerator
Nothing operating cond fan operates slowly at times control panel above door is in and out
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 14, 2010
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Daytime running lights (DRL)
Automatic lighting control
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
2 different models ceiling fans, the remote operates both fans same time. What do I do
In my previous residence, the next door neighbors' remote controlled my fan and its light as well....
I use simpler pull cord fans solely these days. As for dimming (remote or wall switch), LED likely saves the day where fluorescent fails....
Dec 02, 2014 | Dryers
While baking oven starts broiling with no input from controller. f2 is displayed on screen
Hello there:
F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Sep 27, 2010 | GE JKP15 Electric Single Oven
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
No heat from heater ,a/cond works fine fan blows on heat but no heat,no leakage from core
The heater bypass valve is bad.It's located on the heater hose under the hood near the firewall.It looks like a little 3in.diameter black disc with a vacuum line attatched to it
Oct 05, 2009 | 1988 Cadillac Eldorado
Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Jul 18, 2009 | Kenmore 75123 Wall/Window Air Conditioner
99 Yukon - Blower Motor Not Working
replace the A/C control head... very simple to do. Pop off the dash panel and pull the control head out... unplug the 3 harnesses and there you go.
Jun 02, 2009 | 1999 GMC Suburban
E1 f2 error
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
Good Luck
Sep 05, 2008 | GE Profile JT912 Electric Single Oven
Missing manuel Code showing - F 2 -
hi,
F2
F2
Oct 31, 2007 | GE Profile JT912 Electric Single Oven
GE (PSS26MSRSS) Side by Side Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
