Question about Vizio L32 32 in. LCD HDTV
The unit was working then it made a strange sound and went off and am unable to turn it on with the remote or the switch
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
PANASONIC CS-CU E24PKR fault code H00
H00 No abnormality detected - Normal operation
You may have a problem with the outdoor controller, the indoor controller or both. Power outages can do some strange things to the electronics. Turn the A/C isolator off for five minutes and back on again to be sure the problem is still there. You could also try this:
• To clear memorized error (Protective operation) status
after repair:
1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
Jan 31, 2015 | Panasonic Heating & Cooling
I have a SSU320RHL-GB the unit works well in the automatic mode with the remote but when you try to go to the manual override the pilot will not stay lit, it lites but will not stay lit. It is very...
That is very odd. I've been in the hearth business for 15 years and have never been faced with this problem. Although, I suspect the remote receiver box is the is the culprit. To test this theory, turn the receiver box OFF. If you're unable to do that, remove the batteries from the receiver box and try operating the stove manually. If it then operates manually, it may be the reciever is wired incorrectly or the 3 position rocker switch on the stove, needs to be switched from Remote to ON. That would then override the remote receiver.
Hope this helps you and thanks for choosing FixYa.
Aug 18, 2011 | Procom SSU320RHN-GB Heater
The screen on the remote is working however it doesn't seen to be make a connection to the unit therefore the aircon unit isn't turning on. How can we fix this?
This sounds strange but if you have a mobile phone with video recording on it, run the video whilst pressing the remote control. If you point the camera at the end of the remote (Where the glasslike bubble is), you should see it flash ( On the camera) You will not see anything with the naked eye, you must look at it through the camera while on video record. If you see a flashing, it means the remote is OK and you will need what is called " a receiver board" in the indoor unit of your aircon. If it doesnt flash, it means the remote is faulty. Try the manufacturer for a replacement .
Bye the way, any remote control can be tested in this way... try it with your TV remote to confirm it works..
Jun 16, 2011 | Heating & Cooling
Power went out and now ceiling fan won't work
Before you try all of that try the on/off switch, I tried holding down the light switch on the remote and turning the on/off back and forth several times and then the light came on... it is very tricky, but I knew my battery was good, and the fan worked before the power went out and the dip switches did not need reset or changed. I tried many different combinations so I am not sure what tripped it up, but try that before changing anything or pulling the fan cover off. Best of Luck
Sep 07, 2009 | Hampton Bay Dryers
Unable to program remotes from opener
TRY UNPLUGING THE UNIT WAIT ABOUT 5 MIN. PLUG IT BACK IN CLEAR THE CODES BY HODING DOWN THE PROGRAM BUTTON FOR ABOUT 20 SECONDS.
NOW YOU ARE READY TO PROGRAM A REMOTE TO THE SYSTEM.
HOPE THIS HELPS
Aug 13, 2009 | liftmaster Chamberlain Garage Door Opener...
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
Clicking sounds
i had this condition on another denon a/v receiver it started clicking got worse as time went on progressed to snaping sound more so when switching modes ie dvd to tv etc then l/frt speaker would cut out found by gently tapping l/side of the chassis it would pop & snap sent it out to denon & they replaced the dsp unit no problem since hope this helps Alan
May 22, 2007 | Denon AVR-4306 Receiver
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
