Question about Canon GL2 Mini DV Digital Camcorder
I just bought a canon Gl2 camera used on Ebay. I did the routine check, and everything seemed cool. I messed around with the zoom, and noticed that when I zoom in, at about 50 percent, it gets really blurry. I thought at first it was because I was too close to the object I was zooming, so I tried all sorts of areas and objects and it's apparent it's a true zooming issue. I typed in Canon Gl2 zoom, and there are already "Canon Gl2 zoom issues" popping up. I found a guy who had a "sticky or non responsive zoom rocker". Mine's not sticky, or non responsive. It just doesn't wanna focus after 50 percent. Is this something I can take apart and fix myself? Is it worth it? or just take it back?
    Genius:
  • 1,812 Answers
This happens when the internal focus lens is off track, usually caused by impact and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 14, 2010
Cannon MVX3000i goes into auto zoom
had an issue like that with my GL2 at an older stage. Ended up the dimmers and light combination would emit IR that confussed the camera into thinking I was using the remote control to zoom it... if it has an external (not in the lens) pickup you might try covering the IR reciever on the camera with dark tape (if you use masking tape or electrical tape, take it off after you are done as to not leave goop all over your camera)... a post it might work well. Otherwise look in the setup and turn off the remote if possible.... Just one possibility....
Feb 26, 2010 | Canon MVX330i Mini DV Digital Camcorder
The side grip zoom button does not work.
Camera needs service. There is an assembly that get replaced in the side cabinet, it's a flexible printed circuit or FPC. You can expect to pay ~ $220.00 for this type of repair. Of course, don't overlook having general maintenance performed while it's in the shop... usually it's just a tad more labor, and the cost of parts. www.AVRepair.com is one such place.
Jan 02, 2010 | Canon GL2 Mini DV Digital Camcorder
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
Stuck zoom too!
I had the same problem, but it was a case of getting a loose screw tightened up inside the lens.
I took it to an authorised dealer and it cost me the equivalent of about US$25 to get repaired, with the obvious advantage of not messing with the warrenty.
I also hadn't bumped my lens, and I only bought it in July, 2009.. so effectively, new. I did notice the zoom getting looser with time, and would fall out of the chosen zoom length when pointing down (and indeed, up).
Sep 30, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Camera GL2 Zoom Noise Problem
the sound is either the tape reels spinning or the zoom can you possibly send me a copy of the sound mattgandersn@aim.com
Feb 17, 2009 | Canon GL2 Mini DV Digital Camcorder
BLACK SPOTS CANON GL2
normaly whatever editor you are using will be able to import it. windows moviemaker is preinstalled on all pcs so thats free and you can use that.
Jun 11, 2008 | Canon GL2 Mini DV Digital Camcorder
Zooms in without pusing control button
I am one of the lead technicians at VideoOneRepair.com. We are a repair shop1.gif that specializes in only Sony and Canon Prosumer camcorders.
The problem that you are experiencing is a common complaint on the Canon Gl2 camcorder. There are two different common parts that can cause zoom problems. One is that the zoom control on the side grip goes faulty and will need to be replaced ,this repair parts and labor is $195. The second problem is a bad flex PCB and this repair parts and labor is 306. Both of these repairs include cleaning and servicing. The return shipping is free. We also grantee the entire camcorder for 6 months parts and labor.
If you have any other questions please feel free to call, email1.gif or post you questions here.
Sincerely,
Sheryl Bahr
Canon GL2 Camcorder Repair
VideoOneRepair.com
888-283-2228
Mar 20, 2008 | Canon GL2 Mini DV Digital Camcorder
Zoom control not working
Sounds like the zoom control needs cleaning I run two of these and they have both gone within a week of each other, it seems to be a common fault. Will need to send them to a repairer as they are fiddly to do.
Jan 22, 2008 | Canon GL2 Mini DV Digital Camcorder
Zoom Control
on the gl2 it is supposed to be slow its not broke theres two switches that can lock the camera and the one by the mic is very slow but ok
Sep 11, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 shuts down automatically while in record mode
Turn off the power saver mode. I did it and it works!
Apr 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
121 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
