Question about Panasonic KV-S2026C Pass-Through Scanner
Roller fell of on the inside of panasonic kv-s2026c
As i was cleaning the scanner, i tapped a small roller on the inside front of the scanner & it came out. the rest are in pretty tight. this one you barely move it & it falls. how do we fix this.
  • John Dezember May 11, 2010
    Is this a hard plastic roller that runs the width of the scanner and sits near the bottom? If so this roller is only held on by two metal clips on each side of the roller. It is normal for this roller to seem loose.
Yes normal. thier are 2 black rollers. they are spring loaded so when the door is closed the correct tension is applied to them.
Bboss
Posted on Dec 31, 2008
Kv-s2026c paper jam
Are you just receiving paper jam message or paper is actually jammed in the unit.Or the paper is getting jammed every-time while getting the printout.Click this link below :-----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Panasonic KV-S2026C Pass-Through Scanner
KV-S2026C not scanning
does this unit show any error?
how old is this unit> is it under warranty?
Oct 02, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Auto crop and Deskew ?!! everytime i try to scan it pops up with a message saying...these settings will be ignored: -autocrop -deskew we have to scan document that are really long and i cant have it...
I know this is very old and you have probable answered your own question, but in case anyone else finds this...
Search google for panasonic reference area/roller, they are two rollers inside your scanner, if they are set to white Deskew and Autocrop amongst others will be disabled, if its set to Black they become available, I spent two days trying to sort this.
Oct 19, 2011 | Panasonic KV S2026C Path-Through Scanner
My panasonic kv-s2026c has a black line running down the left side when I scan my documents. I have cleaned the rollers, used air canister to see if anything is stuck in there. That didn't help
On the CD that came with the scanner is a directory called "Shading Utility". Copy this folder to your PC. Put a blank piece of copy paper into your scanner. Open up the Shading Utility folder and then double-click on the shadingutility.exe. The password is "GOSHADING" without the quotes. This process will take a few minutes but it will re-align the lens in the scanner which has gotten out of alignment through vibration. This is what is causing the vertical black line on the left side of the page.
Jan 13, 2011 | Panasonic KV S2026C Path-Through Scanner
Line in scanned document
Its dirt! It takes just one tiny speck of dirt on the lens to make a vertical line.
We have some scanner maintenance videos;you want to clean the CIS front sensor.
Regards,
MyEfact
May 12, 2010 | Panasonic KV-S2026C Pass-Through Scanner
Scanner pulls through more than one sheet at a time, continually, but not all the time, and often jams for no apparent reason.
Clean the rubber rollers with a damp, but well wrung, cloth. No solvents please!. This will remove all the paper dust and give necessary grip to the rollers. If they are worn out you need to replace them.
S. Mohan
Oct 22, 2009 | Panasonic KV S2026C Path-Through Scanner
Yellow light is blinking and error indicates clean rollers. Rollers have been cleaned but message keeps coming back. No problems scanning.
Panasonic includes a user utility with this model. The utility can be accessed via Start>All Programs>Panasonic. In it you will find a display and reset function for the cleaning count. Sorry I don't have more specifics, its been a while since I worked on any Panasonics.
Apr 06, 2009 | Panasonic KV S2026C Path-Through Scanner
Grinding noise
There is usually a slide type button somewhere around the outside of the scanner and it usually has a lock & unlock sybol on it. You may want to make sure that it is slid totally in the unlock position because it could be getting caught inside once in a while if the button is say half way between lock and unlock... Hope this helps...
Sep 24, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Noise
this is a normal thing with scanners i have read reviews about different scanners where the scaners were good prices the only downfall was the noise
Jul 03, 2007 | Panasonic KV S2026C Path-Through Scanner
Panasonic KV-S2026C Pass-Through Scanner Logo
167 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
