Question about Jabra Original SP200 Bluetooth Visor Speakerphone Black SP200
Synchronize device Require passkey to synchronize
Synchronize device Require passkey to synchronize Blackberry to Bluetooth device
    President:
  • 1,118 Answers
Firstly, try '0000' (four zeros). if it fails, switch to '1234'. If it keeps failing, try '8888'.
Hope one of these codes might suit your needs.
Regards, Carlos
Posted on Sep 14, 2010
  • CARLOS R SOUZA JR
    CARLOS R SOUZA JR Sep 14, 2010
    The passkey for your case is confirmed to be '0000' (four zeros). I'd given you a range of codes because, at the time I posted my answer, Jabra's website was (and still is) incredibly slow (at least here). Anyway, if your bluetooth car kit's user guide happens to be missing, fee free to download it fromhttp://img6.jabra.com/sites/Jabra/GNimag...
    Regards,
    Carlos
  • CARLOS R SOUZA JR
    Don't know why fixya seems to be cutting the whole URL in my post. it is
    .../Jabra_SP200_UM_III_10021.pdf
    It seems to be the file type (pdf) was missing...
Is my dv52132dx bluetooth compatable to my blackberry 9350? I put my blackberry in the listen mode and go to add a device on my hp laptop and I don't get a response from either..
You need to choose listen on your black berry mobile and than search for devices from laptop.
Below given is the online user manual of your blackberry. On Page 26 it tell you how to connect it to bluetooth devices.
http://docs.blackberry.com/en/smartphone_users/deliverables/4576/BlackBerry_Storm_9530_Smartphone-US.pdf
=========================== Pair with a Bluetooth enabled device Some Bluetooth® enabled devices have a passkey that you must type before you can pair with them. 1. In the Bluetooth setup application, click Search or Listen. 2. If necessary, click a Bluetooth enabled device. 3. If necessary, type the passkey for the Bluetooth enabled device on your BlackBerry® device. 4. If necessary, type the passkey for the Bluetooth enabled device on the Bluetooth enabled device. ===========================
Jul 06, 2011 | HEWLETT-PACKARD HP Pavilion Laptop / Intel...
Tip
BlackBerry - Synchronize data between mobile and computer
<ol> <li>Firstly you need to connect you blackberry device to you computer </li> <li>Then open BlackBerry Desktop Manager manual, if it didn't open automatically when device was connected to computer</li> <li>Then when the application is up look for synchronize and click it</li> <li>After which you will select the check box beside one or more action </li> <li>Then click synchronize </li></ol>
on Jan 08, 2011 | Cell Phones
"When I try to sinc my blackberrycurve to my
Try these simple steps: 1) Disconnect your Blackberry from your computer 2) Start DM (Desktop manager) and on the upper right hand corner select Options 3) Select "Data Folder Options" 4) Choose "Use this specified folder" 5) Right click the data path and hit "select all" and copy 6) Hit Start and select Run 7) Paste data path into run and hit ok 8) Blackberry folder should open up 9) Find the "Intellisync" folder - select it and delete it 10) Connect your Blackberry 11) Go to your DM's main menu - select "Synchronize" 12) On the left hand side - select Configure Synchronization 13) Press "Synchronization" button 14) When done - select Synchronize (Upper left corner) 15) On the synchronize screen - select only "Synchronize Organizer data" and "Update device date and time" 16) Select "Synchronize"
Jan 06, 2011 | RIM BlackBerry Curve 8310 Smartphone
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How to import calendar and contacts from outlook to BB
Step 1 Install Blackberry Desktop Manager Manager from
http://na.blackberry.com/eng/services/desktop/
Step2
Connect blackberry to your PC using a USB cable and let blackberry device driver install. When device driver install is complete, it will alert "hardware installed successfully" in your windows task tray.
Step3
Run Blackberry Desktop software and choose SYNCHRONIZE option.
Step4
Now choose CONFIGURE and you may select CONTACTS, CALENDAR, NOTES, and TASKS databases by clicking check boxes next to each. After you select each item, it will ask which application you would like to sync it with, you will choose OUTLOOK for all.
Step5
Now click OK out of all windows until you are at the main blackberry desktop manager screen. click SYNCHRONIZE. Make sure that the SYCHRONIZE ORGANIZER DATA check box is checked. Now click SYNCHRONIZE NOW to begin synchronization.
Hope it helped.
Nov 21, 2009 | Cell Phones
I can not sync outlook to my blackberry
First Make sure you have installed desktop manager software in your computer which has outlook configured in it.
Then connect your blackberry to the computer using data cable and follow these steps given below
1. open the desktop manager and click on Synchronize
2. Click on synchronize towards your left hand side of the screen
3. Again click on synchronize below configration towards the left hand side of the screen
4. then again lick on synchronize towards right hand side
5. Then you will get option to select device application and then click setup
6. Then you will get option sto select available destop application select Microsoft outlook and click next
7. Then it will give you synchronize options ( two way or one way )
8. In the next screen select outlook and click next.
9. Now it will give congratulations screen. click finish
Nov 07, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Receiving Intellisync message
for this you need to reconfigure the synchronization settings for your destop organizer proram
please follow the same.
1. connect Blackberry to the computer.
2. open desktop manager and click on SYNCHRONIZE.
3. click on the CONFIGURATION tab
4. click RESET CONFIGURATION
5. click CONFIGURE SYNCH
6. Select a BlackBerry device application (Address Book, Calendar, MemoPad, or Tasks), then click Choose.
7. click BROWSE
8. add the folders you want to synchronize and then click OK
9. click OK to close the chose application window
10. click OK to close the device cinfiguration window
11. synchronize the organizer data on your black berry device.
Jul 10, 2009 | RIM BlackBerry Storm 9530 Smartphone
Jabra Original SP200 Bluetooth Visor Speakerphone Black SP200 Logo
135 people viewed this question
Top Jabra Cell Phones Experts
xalint1
xalint1
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
