Question about LG Microwave Ovens
My LG Orbit (round cavity) door has been sticking (have to open manually while pushing button) but now won't open period.
SOURCE: Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Posted on Oct 28, 2007
clyde2j2
  • 137 Answers
SOURCE: Spacemaker II door latch problem
Most microwave ovens have catches that are shaped like hooks, these hooks catch on a fixed bolt or a raise in the frame of the oven.
The next time you get the oven open check these hooks to see if the springs are working in a strong positive manner, or if you have to push a button on the model check to see that the button releases the hooks.
Hope this helps.
Posted on Feb 16, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
  • 8909 Answers
SOURCE: The door sticks and will not open automatically
Clean the door swith housings and re align the door.
That should do it, any other problems will become apparent when you examine the door switch holders.
Posted on Nov 03, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave wasn't heating properly and now the
You can remove the control panel assembly, then you'll be able to see the door opening parts.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The Dacor PCOR30 is essentially a rebranded Sharp R-1874, so the relevant Sharp service manuals (here and here) will help you with disassembly if you need more help.
The Sharp manuals will not have the proper Dacor part numbers.
For that, see the Dacor PCOR parts list here.
Our favorite place to order Dacor parts is by part number from the Pros here.
Posted on Jun 21, 2011
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Often that is due to accumulated grease on the door open button and the opening in the plastic control panel frame in which it moves.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
You can find links to helpful exploded view diagrams and part ordering help for most brands here.
I recommend that you bookmark that link to your favorites.
Jan 09, 2013 | LG LCRT2010ST Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
Probably a bad door switch or mount. The door switch help file is here.
On some models though (you didn't mention yours) the door circuit is very complicated, and may be showing the door error due to a blown fuse or cavity TCO.
Accessing the cavity TCO for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
The drawing below shows what to check:
You can find handy exploded views and order parts by model number
here.
Dec 04, 2011 | Whirlpool Microwave Ovens
How do I repair the door latch for a Sharp Carousel R-530ESF microwave oven? The push button won't open the door. I had to use a putty knife to push the latch up and open the door.
The service manuals are at our site here and here.
You can order parts from the Sears Parts Direct Web site image-4235112-10659157 or Encompass here.
Jul 07, 2011 | Microwave Ovens
Our LG microwave (LMA 1560SW?LMA1560SB) has a door that won't open. The open button will push in, but not release the door - the plastic button cover pops back out, but just the cover - not the whole...
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
Mar 20, 2011 | LG LRM1230W Microwave Oven
The door sticks and will not open automatically when you push the button to open the door - you have to manually open the door.
Nov 03, 2010 | Amana AMC4080 800 Watts Microwave Oven
My daughter put a metal ring in the microwave to heat up. I was not there, so I did not know what happen and if sparks flared up. But the microwave kept working OK for half a day before acting crazy. ...
There really shouldn't be a correlation between the metal ring in the oven cavity and the erratic operation of the control board. Although it might seem suspicious, what happens inside the oven cavity stays in the oven cavity.
Jun 20, 2010 | General Electric Microwave Oven
Hope this helps.
Feb 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
