Question about Fuji DocuPrint C1110B Laser Printer
I have a xerox C1110B printer and it is printing very faintly. I have put a new toner in it but this hasn't helped. I've run maintenance mode to clean developer, clean drum and refrest toner and still no joy. it is telling me to now order a new drum cartridge, which I have done. Do I have to wait for this to fix the problem or could I try something else? thxs
  • 2072 Answers
SOURCE: xerox work centre xl2130f developer
It goes in with the toner. The developer and toner mix in the cartridge. Empty the old out and put it in with the toner.
Good luck.
Posted on Feb 07, 2008
  • 2072 Answers
SOURCE: Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
Posted on May 15, 2009
n25an
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
Posted on Dec 24, 2009
  • 4 Answers
SOURCE: where can I download the driver for Fuji Xerox
You can download a latest driver for Fuji Xerox Docuprint c1110b Color Laser Printer in this URL
http://www.fujixeroxprinters.com.au/en/support/Downloads.aspx?product=8645&category=5726&os=8388608
Driver Version: 2.6.15
Driver Languages : English, Chinese - Simplified, Chinese - Traditional and Korean.
Operating System
Microsoft Windows XP Microsoft Windows 2000 Microsoft Windows 2003 Microsoft Windows 2003 64bit Microsoft Windows Vista 32bit Microsoft Windows Vista 64bit Microsoft Windows XP 64bit Microsoft Windows 2008 64bit Microsoft Windows 7 Microsoft Windows Server 2008 Microsoft Windows 7 64bit
Printer Language: PCL
WHQL: Yes
Posted on Mar 23, 2010
  • 4 Answers
SOURCE: My xerox colour laser C1110B has started printing
All type of chemical coating "INKJET PAPER" can harm your laser printer.
If you want a perfect printing, just use a high quality plain paper.
Good luck.
6110- Faint Printing in same spot all the time
Well measure the repair costs agains the cost of a new printer.
so you have printed 15 000 pages? pretty good for 200 usd printer I must say.
Il have a look what xerox says about this.
May 12, 2008 | Xerox Phaser 6110 Laser Printer
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 27, 2012 | Xerox Phaser 6280 Clr Laser Printer 26Ppm...
I have just put in a new toner but still the
change the print mode and try in printing best mode.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Brother DCP-8065DN Laser Printer
Problem with Xerox Phaser 6110 black toner.
Yeah it is a problem with the chip that is on the cartridge. You can go to the Xerox.com site and contact them directly by phone or e-mail.
Just once at the xerox.com site, select your country.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
Faint copies, despite new cartridge.
Go to Additional Functions> Common Settings> Toner Saver Mode and make sure its off.
Sep 27, 2009 | Canon imageCLASS D320 Digital Copier
Very faint printing in xerox 3117 laser printer
my ml 2010 never has printed as dark in the centre of the page even when the toner is full?
Sep 02, 2008 | Samsung ML 2010 Laser Printer
Xerox Phaser 7300dn
Dear try upgradiing the firmware. And if possible contact authorised service center for further assistance. Else update for further assistance
May 28, 2008 | Xerox Phaser 7400DN Laser Printer
Fuji DocuPrint C1110B Laser Printer Logo
264 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
