Question about GE PCF25PGS Side by Side Refrigerator
Goes into defrost to long, thaws stuff out then starts freezing again
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You will need to change out the defrost timer/control board....
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 14, 2010
Feezer shut down with hi-temp alarm
Sounds like a defrost problem. Water came from frozen evaporator that thawed after being unplugged. It will operate great until evaporator freezes over again because it's not defrosting. Defrost components are defrost timer or Board, defrost heater, and defrost thermostat. One or more of those components have most likely failed. Also be sure Freezer / evaporator fan is working.
Aug 29, 2017 | Refrigerators
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Freezer is over freezing/ice-ing up behind the board {where all the wires/fans/stuff is} thus not keeping fridge or freezer as cold as it should be.
You fridge has a broken defrost controller or a broken heating element.
Go to Roper online to find your parts and then see if you can buy them either at applianceparts.com or ebay. These are good cheap ways to get your stuff sent directly to you!
Then, unplug the fridge, thaw it out. And while its unpowered and thawing replace the two parts. Refer to your units parts diagram for parts locations. The controller should just be hiding down underneath or in back and the defroster heating element is usually under the freezer.
Good luck and be careful!
Feb 08, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerator/freezer won't stay cold.
With the defrost timer being replaced already it sounds as if the repairman is not looking at the real problem. Unit works for 2 days then things start thawing. Hint Hint... it is not defrosting. There is a heating element inside the freezer section attached underneath the internal tubing that melts the ice every 6 to 8 hours via the defrost timer depending on the defrost timer installed. To prove that it is not defrosting..... just unplug the unit and place a stand fan blowing into the freezer for about 90 minutes. I would bet that once you plug it back in it wil work for 2 days and the problem once again repeats. With 2 calls on the same unit and you still have the same problem I would be calling the service people back and demand they fully troubleshoot the defrosting element and thermostat. Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of a new part if required, they should wave any labor and service call fees.
Jan 02, 2010 | Whirlpool Refrigerators
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
ICe build-up on coils and frezer does not freeze after a few weeks from thawing.
Check the defrost timer which may be behind the kick-plate, inside the control panel or an Adaptive Defrost Control (motherboard) on the back.
The freezer goes into a defrost mode, everything thaws then
most likely the defrost timer is going bad... staying in defrost mode too long replace it (is located under cover where temp controls are on most brands)
Nov 24, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE PCF25PGS Side by Side Refrigerator Logo
57 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
