Question about Mastercool 67680 Evaporative Cooler Air Conditioner
I have a Master Cool CHC651E. The water pump does not work the past few days, I removed the pump, cleaned it and it ran ok out of the unit, It runs ok installed and using the test button on the panel in the unit. But not with the thermostat. Any idea's.
  • Jay Walters
    Jay Walters Sep 14, 2010
    Can you tell me where the relay is typically located?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue is with the water pump that has gone bad and should be replaced. As everything else is working fine so don’t think the issue is related to anything else, when the pump goes bad it should be replaced as it cannot be repaired. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 14, 2010
  • 2,299 Answers
Is the thermostat pulling in the relay? There is a relay that should pull in with the thermostat. Either the transformer that goes to the thermostat could be bad and not pulling in the relay.
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
2003 GMC Savana Van. The resevoir is full. The radiator is full, yet rusty looking water. Ran hot, thermostat redlined. Let engine cool. Made it a few more miles. Mechanic wants to do water pump,...
Idea is simple, go to a actual radiator shop to see water is circulating , this is a clogged radiator/ or stuck thermostat or water pump. Master cylinder and serpentine has Nothing to do with your issue.
Apr 12, 2013 | Cars & Trucks
How do I clean / sanitize my sunbeam humidifier swm5250 with bleach?
I'm no expert, but a friend of mine loaned me her humidifier recently and she just put some bleach and water in the tank and cleaned the tank with that. It did leave a smell of bleach in the tank that could be smelled any time it ran, but after a few refillings, it went away, and I figure if it smells there must be a little left, which means it should clean the working parts fairly well too. (while you're running it the first few times) And the medicine tray in the SWM5250 is dishwasher safe, so I would just run that through the dishwasher, but bleach should be fine for that too.
Jan 27, 2011 | Sunbeam Humidifiers
I have a 1996 chevy cavalier LS 2.4 liter. a few years ago someone poured sugar in the gas tank but the car still ran ok. about a year after that the fuel pump went out. I removed the gas tank and had...
was the fuel filter changed. and you should also check plugs and wires.for a missfire problem. if you dont get proper spark to plugs, it will misfire and be sluggish. have a good day !!
Dec 10, 2010 | 1996 Chevrolet Cavalier
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Cuisinart Coffee Maker Model # DCC-1150
Unplug for longer than 15 minutes to completely reset it
Oct 09, 2008 | Cuisinart DCC-1200 Coffee Maker
XP 2070 Won't Stop Beeping
Okay, I had the same problem, started beeping and lights flashing one day, unplugged it and it was okay for a few days then this started happening more often until the machine just beeped and blinked all the time and would not make espresso. When I called Krups customer service I was told it sound like a circuit board problem and to send it in, yes its under warranty but I have to pay shipping both ways, so I decided to check it out myself. So here is the bottom line and what worked for me, I removed the espresso screen (above coffee grounds holder, 1 phillips screw) and ran 4 tank fulls of descaler thru the machine. the hard part was getting it to pump thru the machine. I found if I ran water thru the hot water/steam nozzle first I could get it to run 1 or 2 cycles, I also found that by removing the water tank and turning the system on for a few seconds and running pump dry (not recommended) I could get it to cycle without blinking for a few turns. Ran the 4 tanks of descaler thru, then ran 4-5 tanks of water thru into a bowl until it ran thru clean. The machine is 4 months old and I was shocked at the amount of crud that came out. It now runs fine and no more blinking, If indeed this is the fix for this you would think someone at Krups would have a clue, but I guess there a useless a the owners manual for the xp2070.
Thanks and I hope this helps.
John
Apr 24, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
129 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
