My new G Drive won't give me the permissions (Mac) I need to set it up. I did a repair permissions and a verify permissions but neither solved the problem. How do I get the permissions? I am the administrator.
  • 734 Answers
This may be a shot in the dark but it might get you going in the right direction.
To enable permissions, select the partition in on the Desktop and show its information page by hitting Command+I. Expand the "Ownership & Permissions" section and make sure that "Ignore ownership on this volume" is not checked.
Posted on Sep 14, 2010
Samsung S2 1TB Hard Drive on my mac?
settings issue but more importantly the drive must be formatted for a mac. if that has not been done then that's what's on order.
back up data first though
Jun 18, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
Tip
Repairing Permissions
If you have a program on your Mac laptop or desktop that is not working as it should or something is just not right, and your Mac is not doing things like you know it should, you may need to Repair Permissions. This one thing may solve the problem you are having with any program or the hard drive itself. The procedure to Repair Permissions is an easy repair. In order to repair permissions simply restart your Mac before you go any farther. After it has completely started do not open any programs at all. Now open the Applications folder >> click Utilities >> click Disk Utility. On the page that comes find your Mac hard drive on the left and left click it. Now find the First Aid tab on the upper part of the screen and make sure you are on that tab. Look below and click Repair Disk Permissions. No need to verify permissions, just go ahead and repair them. Depending on how long it has been since this was done of if it was ever done, it can take up to 1 hour to complete. When it is finished it will show you what was done and if any permissions were not repaired and why. Close out the Utility and restart your Mac. You may be surprised to find out that whatever problem you were having has been corrected. I recommend you Repair Permissions once every 6 months.
on Dec 01, 2009 | Computers & Internet
Hi My system speed is getting low. I have no registry cleaner or CCleaner (as in window) What is similar for MAC-OS? Kind regards
I would first try repairing your disk permissions. Go into Disk Utility, then click on your internal hard drive. (Not Macintosh HD, the one above it) Under the first aid tab, click repair disk permissions. If that is grayed out, then click verify disk permissions.
Feb 12, 2011 | Apple Mac OS X 10.4
My macbook air cannot preview anything by its Preview application. i cannot open iphoto. when i start, if i open Macintosh HD or any other folder on Desktop then I cannot open system preferences and vice...
I would start by attempting too restart. If this does not fix it, open Disk Utility (Applications -> Utilities -> Disk Utility). From here click verify permissions and then verify disk. If either of those come up with errors, then click the corresponding solution (repair permissions or repair disk). This should solve any problems you are having, but if it does not, Insert the USB drive that your MacBook Air came with and reinstall the OS. Good Luck!
Dec 26, 2010 | Apple MacBook Air
When powering it up it starts to boot I get a blue screen then it goes black where do I start ?
Try starting your mac from it's install disc.
1) First turn off your computer.
2) Then restart it, right when you push the power button to turn it on, press the option key down and hold it
3) pressing the option key will bring to a screen where you can choose your startup disk. Usually, you'll see your Macintosh HD available to startup from. Don't choose anything yet.
4) Insert your install disc into the CD slot.
5) wait a couple of seconds and then clock on your install disc as your startup option.
6) after clicking on the disc, go to the menubar and click on Utilities then disk utility.
7)once the disk utility app is open hit "verify disk permissions"
8) after you've "verified disk permission" hit "repair disk permissions"
- this might take a long time depending how much you've actually done this (which it's good to do every other month or so to keep your mac running smoothly). things might seem to freeze up as well, but it's the mac trying to verify and repair broken permissions on your computer. Don't that's normal.
9) after you have repaired the disk permission, reboot your mac by quitting disk utility and then choosing the startup disk as your normal macintosh HD. That should do the trick. If not, tell us what has changed.
Dec 15, 2010 | Apple PowerBook G4 Mac Notebook
Mac ibook wont boot past biue screen .keep running
Try holding down ALT while booting up and select Macintosh HD. If that doesn't work try inserting your mac osx install CD or DVD restart hold down ALT. Select the CD using the arrow keys after the CD has loaded go up to the drop down menus and go to disk utility, then click on your main boot disk (macintosh HD) and under the First AID tab (if your using osx) click verify permissions and restore permissions, then click verify disk and repair disk. Try to boot up. If this doesn't work restart leaving work mac osx CD in hold down D then follow the disk checker steps. This will tell you if there are any errors on your disk (hard drive). If there are you need to get it fixed or replaced.
Dec 20, 2009 | Apple Computers & Internet
The Updates Mac OS X and Safari Updates can't be Installed.
The latest Safari 4.0.3 requires MacOS 10.5.7 or 10.5.8. Which versions are you using? In fact, all Safari 4 versions including betas require at least 10.5.6. Otherwise IIRC the latest was 3.2.3 of Safari. It should have said that it was not compatible but you may want to go to VersionTracker.com or Apple and check the requirements.
Also run Disk Utility and Verify the disk and Fix the permissions before and after every install. If the Verify gives errors, you will need to boot from your CD/DVD (SOL on MacBook Air, hope you have an external boot disk or drive) and Repair the disk before working on permissions. There are some "errors" shown for permissions that can be ignored, they have used links (lrw...) where it expects none. -Ken
Aug 17, 2009 | Apple MacBook Air
Mac not allwoing write permission to an external hard drive
As long as the Esternal is formatted correctly it should work fine, it might be that you computer wont read the hard-drive, not the files.
Jun 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Gray screen
Use an install disk to repair the hard drive, verify permissions, repair permissions and such. Also try Disk Warrior which can sometimes repair problems that Apple's disk tools can't. If that doesn't work, reinstall OS X. If you don't have a disk go on eBay and buy them. Just make sure that your model is compatible with the set you get. Alternatively you could call Apple, which I believe sells them for about what eBay does, so that's an easy fix too.
Apr 08, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My macintosh keeps freezing and saying cannot comply
in your utilites folder in applications folder start disk utility select you macintosh hard drive from left hand side then select verify permissions , it can take a while to run then when finished repair any broken permissions and finally verify your disk this can take quite a while to do but fixes most problems with mac computers
Oct 06, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
