Question about Kenmore Elite 45986 Front Load Washer
What is the F20 message? - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
ERROR FF20 AND FF5
Hello Heather, this is JK. I understand that you received two error messages, F20 and F5. Typically, the F20 error indicates a communication failure between EOC and ESEC system and the F5 indicates that there is a runaway temperature. Based on the fact that you received both error messages, you may need to replace the EOC (Electronic Oven Control). Hope this helps!
Apr 19, 2014 | Frigidaire Kitchen Ranges
European maps wont load
you'll need a mandatory firmware update
click here
Mar 15, 2008 | Navman F20 GPS Receiver
I am recieving a F20 error message on a brand new whirlpool washers each time i use it. Its a Duet Steam.
F20 means water is not entering the machine at a sufficent rate, check water supply is connected correctly, turned on and hoses are not blocked or kinked or pinched.
Jan 14, 2011 | Whirlpool Washing Machines
Recently I have been getting an F20 error message. What does this mean?
F20 No water detected entering machine
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Aug 31, 2010 | Kenmore Elite HE5t Washer
F20 message on washer kenmore elite HE5t
http://www.fixya.com/support/r3608632-f20_error_code
Feb 28, 2010 | Kenmore Elite HE5t Washer
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Jan 22, 2010 | Whirlpool GHW9300 Duet Washer
Finepix f20 to windows vista
Use a card reader to download your pictures to a folder you create on your desktop.
Oct 05, 2009 | Fuji FinePix F20 Digital Camera
My Fujifilm FinePix F20 digital camera gives me a zoom error message and the lens does not open when I power up
problem on lense .remove ur lens on ur camera and cheak the motorgears which are supporting to move lense
Jul 11, 2009 | Fuji FinePix F20 Digital Camera
Error message on Navman Navman F Series Failure Unable to detect internal memory. Please return the unit to dealer. Can anyone help?
I have a F20 here I am currently tring to fix.
The error comes from the internal memory card being faulty.
It is only a micro SD car.
It may be totally usesless, or need re-programming via the USB port.
You can download the firmware, and it fixes a working MicroSD card.
If your card is damaged, then you will have to replace it, and strip the F20 down to do so.
Then you can upload the firmware.
I warn you, though.
Stripping it down is a bit tricky.
I replaced this F20 memory card, and put on the firmware, but have a new error, that it cant find any maps installed.
Hope this helped you
Michael
Scratchmittens@htomail.com
Jul 14, 2008 | Navman F20 GPS Receiver
Zoom Error
i have a duji f20 le zoom lens partly out when turn on says zoom error can you solve this please
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Kenmore Elite 45986 Front Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
