Question about Sony KDL-52XBR9 52 in. LCD HDTV
I have lost digital reception. I can play DVDs and get analogue TV.
  • 456 Answers
You need to make sure your reception is strong enough to receive digital reception otherwise you will only receive analogue reception and dvd playback ability is normally nothing to do with the TV's reception.
Ensure you have strong reception before doing an auto tune to search for the channels. Good luck.
Posted on Sep 14, 2010
Turn on TV is snow white screen
Check your aerial connection.
Ifit is combined digital/analogue set put it back to digital, white screen used to indicate analogue reception. There is no analogue broadcasting here anymore, only digital. The option should be on your remote.
Hope this issue and you can resolve it.
Good Luck
May 29, 2015 | Televison & Video
Is this TV digital? I've lost channels since the change to digital from analogue
I doubt it has a digital tuner but the owner manual should show that or Google the model number.
Sep 03, 2012 | Toshiba 14DLV75 14 in. TV/DVD Combo
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
Hi Digital channels lost and will not hold
this is a fault of your digital tuner on the mainboard on some models they can be replaced alone others you may need to replace the whole board
Apr 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
TV reception band no longer works
all analogue signals going out means EVERY analogue signal is gone in the TV band. these are now apparently assigned to emergency services in some states.
Jun 14, 2009 | Audio Players & Recorders
Does the Bush LT26M1CA have an analogue tuner
Hi, Your Tv does indeed have an analog tuner for UHF and VHF reception. Remember you need to have an external antenna connected to receive anything via the analog input. On your remote in the upper right hand corner is a button labeled tv/dtv that will switch back and forth between your analog and freeview digital. Good Luck, this should Fixya!
Mar 20, 2009 | Televison & Video
Snowy reception on TV with LG DVB418
have you got both cables going into your video ?? if not you need a video splitter to input both the digital and analogue aerials then have a coaxial cable going to the tv
Mar 08, 2009 | LG DVB418 DVD Player
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
Sony KDL-52XBR9 52 in. LCD HDTV Logo
224 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
