Question about Uniden DCX200 Digital Phone
On 2 of the 4 handsets on my Uniden DECT 2080, the large middle button has stopped functioning properly. It's the button with caller ID, phone book, and arrow buttons. One stopped working about 2 months ago the second one "broke" this week. It seems like only a matter of a couple of months before the others go!
After having the same trouble with my DCX200 and not finding a solution online for the problem, I set out to find a solution of my own. The fix I describe below is probably more of a band-aid than permanent fix but it appears to be working great. The problem, I believe, is caused by the metallic compound that the manufacturer used on the push button contacts in this model of phones and more specifically with the large multi-function button. This compound appears to wear off quite easily with repeated use of the keypad. Along with this I think that the design of the multi-function button did not take into consideration the environment in which it would be used. Not everyone washes their hands and face before using a phone (does anyone?) and between grease, make-up and natural oils of the skin building up and eventually making their way down into the components, this may be a contributor to why these buttons are so susceptible to failure.
On 2 of the 4 handsets on my Uniden DECT 2080, the - _889.jpg What you will need:
1) Small Phillips head screw driver.
2) Small flat head screw driver (not shown).
3) Goo-Gone, Isopropyl Alcohol or some other degreaser/cleaner.
4) Hole punch, preferably smaller than a "standard" hole punch. I found the one I used in my wife's craft supplies.
5) Cotton swabs.
6) Metallic or foil tape. Can be found at any home improvement or hardware store.
Step 1. Remove battery and two screws circled in red with your small Phillips head screw driver.
Step 2. Pry off the dark grey back of the phone case with your flat head screw driver. I found that starting at the base of the phone anOn 2 of the 4 handsets on my Uniden DECT 2080, the - _892.jpgg around the sides was easiest.
Step 3. Being mindful the the wires that attach to spOn 2 of the 4 handsets on my Uniden DECT 2080, the - _893.jpgke the dark grey back off of the phone. Next remove the screw circled in red below:
Removing this screw will allow you to remove the circuit board from the front face of the phone to expose the numeric keypad as shown below. There is a thin white plastic keypad component that will either rOn 2 of the 4 handsets on my Uniden DECT 2080, the - _894.jpgfixed to the keypad or the circuit board when you remove the circuit board from the front face of the phone. Be sure not to damage that.
_894.jpg Take the white plastic sheet and affix it to the circuit board side (if not already on it), with the small black button contact points facing down onto the circuit board as shown below:
Now soak one side of your cotton swab in your Goo-Gone or Alcohol solution and clean both the four small black push button contacts of the large multi-function button on the back side of the keypad and also the contact points on the circuit board. Then take the dry side of the cotton swab and remove any excess cleaner on the button contacts and the contact points. This step is critical. This cleans the surOn 2 of the 4 handsets on my Uniden DECT 2080, the - _896.jpgd makes the push button contacts on the back side of the keypad ready to receive the foil tape.
Pictured below is the cleaning of the push button contacts of the multi-function button on the back side of the keypOn 2 of the 4 handsets on my Uniden DECT 2080, the - _897.jpg> _896.jpg
Also clean the contact points on the circuit board using the white plastic sheet as a guide to where to clean. Don't forget to use the dry side of the swab to remove any excess cleaner:
Now the part that requires of bit of dexteOn 2 of the 4 handsets on my Uniden DECT 2080, the - _898.jpgsing your hole punch punch out four pieces of the foil tape. If you do not have a hole punch or are using a "standard" sized hole punch, you will want to try and use a scissorsmulti-function key on the back side of the keypad:
Harvest the small circles of foil tape that the hole punch punched out of the foil tape.
You can see a couple of them on my finger below:
_899On 2 of the 4 handsets on my Uniden DECT 2080, the - _900.jpgass=
Now using your finger nail, gently remove the foil tape backing on these small circles. Yes, this can be a bit tricky, but I found it to be easier than I expected. With the backing off of the foil tape, affix your small foil circle onto the push button contacts of the multi-function button on backside of theOn 2 of the 4 handsets on my Uniden DECT 2080, the - _901.jpgad as shown below. Do not affix these to the circuit board contacts:
Do this for all four contacts of the multi-function button on the keypad. The picture below shows the finished repair to the push button contacts. I also placed the white plastic film component onto the keypad side to underscore the fact that you place the foil onto the keypad and NOT the circuit board:
Now place the circuit board back onto the front side of the phone (silver side) and fasten down with the screw you took out in step 3 above.
Affix the dark grey back of the phone onto the front side. There is a small plastic On 2 of the 4 handsets on my Uniden DECT 2080, the - _902.jpgngue
at the top of the dark grey back that fits into a groove on the top of the front silver side of the phone. Get that tongue into place first then the rest of the back will snap into place.
After the back has been snapped back onto the front of the phone, fasten it down with the two screws you took out in step 1 in the battery compartment.
Put the battery back in, wait for the phone to turn on and try the keypad out. Below, you can see that I am checking the caller ID side of the mult-function button:
This fix appears to work quite well. I don't know how long the repair will last but it would be easy enough to do again if needed.
Posted on Mar 06, 2011
  • tjrtech Mar 12, 2011
    Thanks for posting this. Our DCX-200 had exactly the same problem, and the fix posted solved it. Took only a few minutes. You do need small screwdrivers, both the philips for screw removal, and the flat for prying the case. Also, for me and our hole punch, the foil tape discs were a bit big, so I had to trim by hand with scissors so that the foil fit over the black nubs, but also moved freely in the countersink of the soft plastic holding all the buttons in place.
    Now to figure out why the volume on the other handset is pretty much DOA. Have to have the phone on hands-free speaker to hear it.
  • virtua1 Mar 17, 2011
    Thanks so much csiguy. Excellent tutorial. You've saved me time, money, etc. This worked like a charm. Two things: my hole punch must be old, or the foil tape I bought was thicker tape - I had to cut the round circles entirely with scissors. Also, the adhesive on my tape was not sticky enough to hold onto the push button contacts by itself. To remedy this, I used some generic elmer's white school glue, letting a bead gather at the top of the bottle. With the tape backing off of the foil, I used tweezers to hold the foil circle and run the sticky side of the foil over and through the white glue. Still gripping the foil with the tweezers, I placed the foil onto the push button contacts. I was careful to make sure no glue got on the clean, contact side. It did not take long to dry, and now the volume on my handset works again!
Need manual
If the manual didn't come along with the phone, it is easier to just look on google for 'Uniden DECT 1480-3 Black Cordless Phone w/ 3 handsets DECT 6.0, Answering Machine, Caller ID' and it should pop right up!!
Jul 07, 2015 | Uniden DECT 1480-3 Black Cordless Phone w/...
Uniden DECT 6.0 Cordless Phone with Digital Answering System has Caller ID Problem - Its not showing the caller Id's and phone book enteries.!
cannot see the caller id working or it doesn't display the number of who is calling. bought these phones a month and half ago.
Feb 20, 2011 | Uniden DECT 6.0 Cordless Phone ID
Caller ID displays number NOT name
is there a sprint/nextel phones that has a name caller id?
Jun 19, 2008 | Uniden DECT 6.0 Cordless Telephone...
Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Mar 13, 2008 | Panasonic KX-TGA101S Cordless Handset
Round button in middle quits working.
Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
The Standby Screen
When the phone is in standby, the handset display shows the following items:
Handset
Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
Using the Four-way Function Key
Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
Using the Handset Menu
To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
Uniden DCX200 Digital Phone Logo
680 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
