Question about Canon IMAGERUNNER 6570 Copier
CanonPC6RE Error code EO10. Motor works, gears all look good. When paper is inserted machine stops and error code comes on. What is needed or how do I trouble shoot it?
Sir, i have canon ir 6570 continueing error code E00073-0001
Posted on Apr 21, 2011
  • 2,036 Answers
I don't know if this addresses your problem, but check this link. If Canon has not already repaired your unit (since September 2006), they may help you out.
Posted on May 15, 2008
ERROR EO10
error E010: Main motor rotation error, please give me the reference of your copier to
tell you what to do.
Sep 28, 2011 | Office Equipment & Supplies
Status Code 19
Look in you menus. Your log print out is probably set to on and set to print out way to frequently. You can turn that feature off.
You can go to Xerox.com, click on Support and drivers. In the search box type in 116 then go to support and then type in Log, There should be an answer there as to how to shut off log printing. You cold also type in code 19 when you get to the support page.
May 05, 2009 | Xerox FaxCentre F116 Plain Paper Laser
EO10 CANON PC940?
E010 is a code indicating main motor failure.In actuality it rarely fails.look for a broken belt or gear in the Main Motor train.Good Luck
Apr 02, 2009 | Canon PC-940 Black and White Copier
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Canon gp 200 error code EO10
that is a main motor drive error code either you have a bad motor or something is locking up
Aug 28, 2008 | Canon NP 6650II Copier
I am getting an error code E000540-0002 on my Canon Imagerunner 2200 and cannot find any information on this particular error code. Yesterday we had the error code to empty the waste toner cartridge which...
"E540" Bin shift motor problem in sorter
in the sorter there is a bar that stacks the paper as it comes out, it may have a bad gear or a staple stuck on the bottom of it
Aug 11, 2008 | Office Equipment & Supplies
I have a brother photocopier DCP-8040/8045D Series. We have a error 7a come up on copier, It started when paper got jammed at ther back of machine and weas pulled out from the back, ever since then when...
Turn off the unit and remove the toner cartridge to visually inspect for more paper. Replace cartridge if necessary. Also the problem may be in the fuser. Good luck and God bless.
Jun 16, 2008 | Brother Office Equipment & Supplies
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
273 people viewed this question
old marine
old marine
