Question about Garmin GPS
Garmin Nuvi 255W - How can I modify or delete a category? I have added a category and have added locations to it but would like to change the name. Thanks!
  • 6 Answers
SOURCE: System Software Missing on Garmin Nuvi 255W
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Posted on Jun 03, 2009
  • 4090 Answers
SOURCE: Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Posted on Jun 30, 2009
  • 4090 Answers
SOURCE: Open the case of a Garmin nuvi 255w
i am wondering why you want to open it.
There are some small parts that will fall out unless you are very careful and even more difficult to put back when you try and close it up
. Other than to change the battery there are no fuses or user repairable parts inside.
Posted on Aug 14, 2009
SOURCE: garmin nuvi 750 won't say street names after upgrade to 2009 maps
User's manual available at www.garmin.com. Select "support", then "Manuals". Enter "mobile electronics"+"automotive"+"model #". Manual says that selecting a language with a person's name will speak street names.
Posted on Aug 21, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 255W, all my data was deleted!
This unfortunately can happen. The 2xx & 2xxW are known to sometimes have the memory corrupted at turn on. Be glad you didn't lose your map or system software. I can understand your frustration losing your favorites.
The next time, once you have all of the favorites back in, connect your Nuvi to the PC and make a backup of the file "current.gpx" from your gpx folder. This will allow you to make a backup of your favorites.
- Jim
SHARCNET-USA
Posted on Jan 12, 2010
My garmin nuvi 255w does not speak street names. How do I set it up to speak the street names?
I'm afraid the 255w does not speak street names. A satnav needs to have "Text To Speech" capability before it can speak the names and the 255 doesn't have it.
Aug 04, 2011 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
NuviĀ® 255W Car GPS Receiver: i have a garmin nuvi 255w and its locked and need ...
I had for 2 years a nuvi 255w and its as working real good. Until one day i tried to open it up and it ask me a code pin. Witch i dont have. Ive been the only one owner on that GPS and never put any pin code on it and now just like that it want one... Grrrr that **** me off i cant use it anymore i dont have any acess anywhere exept that pin code of 4 number,. Is this possibility of update? I dont know I am the only one in that situation?
May 16, 2010 | Garmin nuvi 255W GPS Receiver
How do i get my garmin 255W nuvi to speak street names, it speaks turn at net left or right but no names
The Nuvi 255W is capable of TTS (text-to-speech) and speaking street names. Please see this link on how to set the unit up to speak street names:
http://www.sharc.net/discus/messages/6/74.html?1260198848
- Jim
Jan 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Garmin Nuvi 255W Favorites Backup and Restoration Procedure Models: Garmin...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin 255W WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
Garmin Nuvi 255W Favorites Backup here.
on Apr 16, 2010 | Garmin nuvi 255W GPS Receiver
My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Does the garmin nuvi 255W speak street names
I had the same problem with my nuvi 255w. Called tech support at Garmin and they told me one of the voices under Tools, Settings, Language, Voice has to end in a persons name. I had British English selected and it did not speak street names. When I selected Austrailian Englich - Karen, the street names all work fine.
Dec 10, 2009 | Garmin nuvi 255W GPS Receiver
My garmin 255w will tell me to turn ect . but does not say the street name
you have to change the selected voice form American English to American English-Jack (TTS) or Samantha (TTS). Same way for the other languages.
Sep 28, 2009 | Garmin nuvi 255W GPS Receiver
GPS Logo
79 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
