Question about iRobot Roomba 4210 Bagless Robotic Vacuum
My roombas will start to work and then die immediately. Also,Is there someone in the orange county area that repairs roombas?
    Problem Solver:
  • 28 Answers
Be sure you had replaced the battery with a new APS battery. Also, check to make sure that the cleaning head is free from debris.
Posted on Sep 25, 2010
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Roomba 530 is clicking when running then stops
The battery is not charging and has died a noble death. Buy a new battery.
Nov 28, 2013 | iRobot Roomba 530 Robotic Vacuum
Machine just rotates same spot in a circle
I just repaired my 530 roomba last night. I used a sewing machine brush and cotton swabs. On the bottom of the roomba there is a face plate with four screws. Loosen each of these four screws and remove the face plate. DUST EVERY OPENING YOU CAN SEE, but do it gently. Use NO chemicals. Then there is the area that holds in the brush and roller cartridge. Again, loosen those four screws and remove the corner brush's screw and completely remove that little brush. Then you will carefully remove the "case" holding the brush and roller cartridge.DUST EVERY OPENING YOU CAN SEE. Wipe all the silver contact points..plates on the bottom of roomba and one inside the brush and roller cartridge. At this point, I dampened a paper towel ever so slightly with some window cleaner and wiped and dried those contact points. Then using the brush attachment on my vacuum I gently went over all areas of the body of the roomba to dislodge even more dust. Once that is done, reattach all the parts in the reverse order of how you removed them. I charged my roomba overnight and this morning she was charged and worked as if she were brand new! I hope this helps. If my solution works for you,please contact FIXYA and rate my advice.
Nov 18, 2010 | iRobot Roomba 530 Robotic Vacuum
Roomba red #4100 needs repair does the circle
sounds like you have two different issues here. (Possibly one common)
Clean out the cliff sensors. Under the bumper. blow it out clean. This might stop the reverse circling. The battery is either bad, or the charging circuit is bad. if battery is know good then the problem is the main board needs to be replaced. a bad battery will kill a main boards charging circuit by over working it with shorted batteries
Mar 20, 2010 | iRobot Roomba Red 4100 Bagless Robotic...
Roomba has been scratching my hardwood floors.
My brand new Rhoomba worked perfect the first time. The second time using it, I was aghast to come home to the same issue.
My marble floors now have long scratches across the wide expanses of floor. In the areas where the rhoomba (I witnessed it doing this motion the first time I let it clean) does those small geometric patterns like in confined areas, those same geometric patterns appeared scratched into my marble floors in my condo!!!!
What's worse? They do not intend to do anything to repair the damage....just refund my money.
R---I---P O----F----F! DO NOT BUY ONE!!!!!!!
Jan 31, 2010 | iRobot Roomba 560 Robotic Vacuum
Backward spinning roomba
If you are lucky then one of the 4 sensors under the bumper has dust lint buildup. Blow out these areas and give your unit a good cleaning. If it still continues to do this then the bumper bar sensor should be replaced
Aug 03, 2009 | iRobot Roomba 500 Series Virtual Wall...
Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Nov 19, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba got stuck and now it won't go
Would it be that you wound up with someone else's problem and that is why they sold it at a garage sell?
May 17, 2017 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba just runs in small circles
i just recently had someone bring in a roomba discovery and all it would do is stay in a tight 4 tile area and go in circles. battery was fully charged and all bumpers were clear.
i took a can of air blast for cleaning computers and blasted the area on the bottom underneath the sensor and watched as several dust bunnies came flying out.gave it a few more blasts for good measure and put it back on the floor and hit power then clean buttons.
thing went in same tight circle for 2 passes then the circle got bigger for 2 more passes , blue light indicator came on and it made a straight line dash across to closed door and started following the edge and criss-crossing the room.
called the owner back in to test and it repeated the same moves when she started it and all appeared to be working normal again.
Aug 13, 2008 | iRobot Vacuums
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
257 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
