Question about Hamilton Beach Water Cooler with Storage Cabinet
Looking to buy the spill resistant piercing valve part no. HB-CT-1005
My cooler is leaking, and I believe is missing the spill resistant piercing valve. Where can I purchase a valve.
Posted on Sep 16, 2010
Location of bullet piercing valve on sanyo sr4433s compact refrigerator
Does the unit have a manufactures process stub on the compressor casing. That is where I put piercing valves to add refrigerant. Remember that EPA does not allow piercing valves to remain on system and the hole it forms has to be brazed shut. So if it does have a process stub place the peircing valve close enough to the end so you have enough stub to pinch off to braze thehole shut.
If there is no process stub, then install piercing valve in a convenient location in the suction piping and pierce the line. Remove the refrigerant and install a "tee". On one leg of the "tee" install a schreader valve pressure tap and rebraze the joints. Perform and pressure and vacuum test to check for leaks and weigh in the correct amount of refrigerant. Once your proficient at this procedure, it should take about 60 to 90 minutes depending on obstructions around compressor.
Just a comment, low air flow on evaporator give that same indications as a low charge. Make sure the evaporator fan is working and you have good air flow through evaporator section.
Hope this helps
Dec 09, 2014 | Sanyo Refrigerators
Bios page won't function. I'm trying to Setup with F2 but none of the functions work. I'm using an EE pc 1005 HB.
Hello wmalvinx.
in the manual they say press F2 twice.
first press will show then post screen
sec. press open the bios.
mfg Gue
Feb 26, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Can an LG LWHD1200 HR be recharged? If so, where are the service valves? Heat works fine...not blowing cold air
Hello, the unit can be recharged but piercing valves must be added to the high and low sides of the system in order to recharge. They are valves that piercebthe tubing and gauges can be attached to add refrigerant. Here is a link to where you van buy piercing valves http://www.centurytool.net/14809_Robinair_Easy_Tap_1_2_5_8_Line_Tapping_Valve_p/ro14809.htm
Jul 16, 2011 | LG LWHD1200HR Thru-Wall/Window Air...
Can this air conditioner have freon added? It's not cooling as well as it has in previous years.
Hello, yes the unit can be recharged but you need to install a piercing valve on tje low side of the system to charge in the refrigerant here is a link to where you can buy piercing valves. http://www.globalindustrial.com/g/hvac/parts/ac_accessories/Supco-Acces-Valves
Jun 07, 2011 | Kenmore Single Room Air Conditioner
Air doesn't get cold like it use to. I spray cleaned the unit and it didn't help. Can the unit be recharged? Goldstar model: GWHD6507R Thanks.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Where can i find to charge my ac in the rear in my 2003 windstar van that i have i charge the front and it blows out cool air and it blows hot air in the back and i dont know how to charge the rear up...
If the unit has charging valves, they are normally mounted on the suction line which is the larger line for charging, and also on the liquid line, the smaller line to read head pressure. They are 1/4" fittings, with a screw on cap. Has a depressor just like on a car tire to air it up. If they put them on the lines, thats what you look for. Also, look at the valves on the compressor right where the lines go into it. The valves are sometime located there. They will have larger plastic caps on them. Remove the cap on the larger line to charge the unit. They have a valve stem, and you will need a 1/4 wrench to open it after you have your gauge on it. If you can't find any at all, they didn't put them on. They do this on window units. You have to buy what is called a bullet piercing valve, its a saddle clamp fitting for charging units with out valves. They pierce the line and are permanent. I hope this has been of help to you. You can get these at a appliance parts house.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jun 05, 2011 | Heating & Cooling
How to you put freon 134A into a GE side by side?
You will have to install a valce to hook up the hose from the can.
A piercing valve is what is typically used.
http://www.grainger.com/Grainger/items/6X898
I attatches to the low pressure line, and pierces the line at the same time sealing itself to the line. You can then hook the hose to the valve and charge the system.
**Note, any refridgerant other than 134A requires a CFC certification to buy or use.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hamilton Beach Water Cooler with Storage Cabinet Logo
751 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
Dan Webster
Dan Webster
billconfused
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
