Question about Koiiler 8686-W Car Audio Amplifier
Need a manual for a koiiler xm8686 - Koiiler 8686-W Car Audio Amplifier
I have a Koiiler XM-6666 2 channel amp. I was wondering what size fuse i use from the battery source to the amp its self.
You need to match what is on the amp. If the amp has a single fuse, or multiple fuses rated at a total to 80, then you need to use an 80 amp fuse at the battery.
Apr 22, 2011 | Koiiler XM-6666C Car Audio Amplifier
My koiiler fuse is bad how much is one
you will want the one with the 40 printed on it
and you can get them from 1 to 5 dollars depending where you buy on the internet
Sep 27, 2010 | Koiiler XM-7676W Car Audio Amplifier
Need wire diagram koiiler xm 7676
U CAN GET ALL UR WIRE DIAGRAMS FROM PIONEER WEBSITE JUST OUT IN UR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM
Feb 13, 2010 | Koiiler XM-7676W Car Audio Amplifier
Koiiler XM8787 Amp power problem
Sometimes i goes into protection when the amp is overloading with power.. Or the amp is touching metal.. Or the ground wire aint in the right place..Or check your RCA's, Speaker wires? if their earthing your amp..
Jan 13, 2010 | Koiiler XM-8787C Car Audio Amplifier
Blows fuses koiiler amp mx-8686
check your ground thoroughly make sure it is making good metal on metal contact and that there are not breaks or cracks in the outer coating. Most times amps throw fuses for that reason.
Mar 09, 2009 | Car Audio & Video
Koiiler 8686-W Car Audio Amplifier Logo
299 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
