Question about Brother MFC-640CW All-In-One InkJet Printer
Brother mfc-6490cw wrong paper size message when trrying to print envelopes 6.5" X 3.625"
worldvet
  • 859 Answers
SOURCE: Brother MFC-6490Cw Pro
It will print as small as a 3x5 and of course envelopes, you just choose paper type in the printer properties.
It will go as large as a 81/2 x 17.
It only has 64MB of RAM which should be enough.
This is the page where the specs are located.
http://www.brother-usa.com/mfc/modeldetail.aspx?PRODUCTID=MFC6490CW&tab=spec
Hope that Fixes Ya up.
Regards,
Worldvet
Posted on Dec 03, 2008
ITTech7574
  • 85 Answers
SOURCE: Where does the paper go on a Brother MFC 6490CW?
theres a menu button on the wireless printer..go to network and set the configuration from there if your using wireless just set the configuration to the existing wireless device you have and thats it...instant wireless printer connection...also check the manual..hope this helps...
Posted on Aug 28, 2009
  • 526 Answers
SOURCE: I have a Brother MFC 6490cw and can't Get The
if you have done a couple cleanings and it has not helped, its one of 2 things, either your ink cartridge is empty and needs to be replaced, or the nozzles are clogged on the printhead, also air can be in the turbing causing it not to let the liquid flow.
thanks adi
Posted on Dec 03, 2009
  • 51 Answers
SOURCE: paper jams??
click here to download yor required drivers
Posted on May 12, 2010
machambi
  • 194 Answers
SOURCE: Brother MFC- 6490CW 6wks old Screen shows "Error
To adjust your Brother machine's paper type and size settings follow the instructions listed below:
To get the best print quality, set your Brother machine for the type of paper you're using.
You can use seven sizes of paper for printing and copying: Letter, Legal, Ledger, A3, A4, A5, and 4 x 6 in (10 x 15 cm).
You can use five sizes for printing faxes: Ledger, Letter, Legal, A3, and A4.
When you change the size of the paper you load into your Brother machine, you must also change the machine's Paper Size setting.
  1. Press Menu.
  2. Press the up or down arrow key to select General Setup.
  3. Press OK.
  4. Press the up or down arrow key to select Tray Setting.
  5. Press OK.
  6. Press the up or down arrow key to select Tray #1 or Tray #2.
  7. Press OK.
  8. Do one of the following:
    • If you selected Tray #1, please follow these steps:
      1. Press the left or right arrow key to select the paper type you want to use.
        - You can select Plain Paper, Inkjet Paper, Brother BP71, Other Glossy, or Transparency.
      2. Press OK.
      3. Press the up or down arrow key to select Paper Size.
      4. Press the left or right arrow key to select the paper size you want to use.
        - You can select Letter, Legal, Ledger, A3, A4, A5, or 4 in x 6 in (10x15cm).
      5. Press OK.
    • If you selected Tray #2, please follow these steps:
      1. Press the up or down arrow key to select Paper Size.
      2. Press the left or right arrow key to select the paper size you want to use.
        - You can select Letter, Legal, Ledger, A3, or A4.
      3. Press OK.
  9. Press Stop/Exit.
Posted on Jan 02, 2011
I have a MFC-6490CW and when i scan A3 it cuts off the sides of the page when i scan to file
Hi
Please select the auto select paper size option, if this don't fix your problem then go the paper option and manually select the A3 paper size and scan.
Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
HOW DO I PRINT AN ENVELOPE ON A BROTHER MFC 6490 CW
the plastic indicater should slide back and forth to adjustr from paper to envelope
if you dont have the manual to figure this out , go to this link
http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
leave positive feedback for me please
Oct 16, 2010 | Brother MFC 6490CW InkJet Printer
Paper jams??
May 12, 2010 | Brother MFC 6490CW InkJet Printer
Not able to print envelopes . It keeps saying wrong paper
change paper size , and adjust paper holding clip to the size of envelope
Jan 16, 2010 | Brother MFC 6490CW InkJet Printer
How do I print A4 size paper?
select the paper size in your printer program ... control panel, printers, pick yours and open ... find the paper size and select A-4
Oct 27, 2009 | Brother MFC 6490CW InkJet Printer
Printer says "Unable to print 70"
Usually that error means the encoder strip behind the carriage assembly is out of position or very dirty. Best to remove the top cover to correct, you might also find a scrap of paper either on the extreme right or left stopping the carriage from moving properly.
Sep 15, 2009 | Brother MFC 6490CW InkJet Printer
Brother MFC-6490Cw Pro I am considering the purchase of this all-in-one. 1. Does it print envelops? 2. How much on-board memory does it have?
Regards,
Worldvet
Dec 03, 2008 | Office Equipment & Supplies
Brother MFC-640CW All-In-One InkJet Printer Logo
269 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
