Question about Frigidaire FRT22TSE
The plastic bag is stuck in my frigidare ice maker
the dr
  • 447 Answers
SOURCE: How to install a frigidare ice maker IM115.
the wires should be behind a cap that covers the hole for the water tube on the pack panel in the freezer.
Posted on Nov 19, 2007
  • 833 Answers
SOURCE: Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Posted on Dec 24, 2007
rickzilla
  • 706 Answers
SOURCE: Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Posted on Aug 14, 2008
jtbjtb
  • 135 Answers
SOURCE: Ice maker won't stop making ice
If your shutoff arm stays up, the switch inside is bad. Usually have to replace the entire icemaker. Send model # from tag on fridge for part lookup. hope this helps!
Posted on Jan 05, 2009
  • 227 Answers
SOURCE: Kenmore 5814 rotationg ice maker arm gets stuck on pastic piece
Sears should fix it for free.
Posted on Jul 05, 2009
Why won't my frigidare refrigerator make ice
Maybe freezer temp is not sufficient for ice maker to work. Maybe ice maker needs replacing. Maybe water valve is not letting water get to ice maker. Probably need competent service person to take a look
Sep 16, 2017 | Refrigerators
How to remove plastic bag stuck in ice maker
Depends on where the bag is stuck at, just frozen or got wrapped around the cube eject mechanism....if its just frozen then get your hair dryer and melt the ice around it. If it's wound around the mechanism you'll have to remove it from the freezer and after you get it out defrost it and just try and pull the plastic out don't pry on it with anything. Most ice makers are really pretty easy to get out, they just plug into the back of the freezer
Jul 14, 2014 | Kitchen Appliances - Others
I had a plastic bag get stuck in my ice make. I cut away as much as i could but cannot get the ziploc part of the plastic bag out. can you help me? thanks so much
Probably easiest to remove the ice maker to get it out or let it thaw out if that's the problem.
The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
Jul 22, 2011 | Frigidaire FRT22TSE
The ice maker wont drop the ice
Try this pour Hot water in ice maker it may be stuck then see,if blades turn there could be something stuck in ice maker.write back (I had a piece of plastic bag get stuck on the rotateing blades that push the ice up to the drop tub underneath) I hope this works for you
Aug 29, 2010 | Whirlpool Refrigerators
Ice maker seems to freeze up and will not dump the ice. If the ice maker is on, it makes a clicking noise like it is trying to rotate and dump the ice, but it does not happen. It is a Frigidare...
Good day,
Unsnap front plastic cover. There should be a white plastic gear in the center. Inspect closely. If a tooth is stripped out, replace.
Simple repair. One screw. Machine must be unplugged to remove. When re-installing there is a front and a back. Make sure the tongs on the gear are faced away from you.
The ice maker should be removed, and the ice dumped out while performing the repair to take the stress off the new gear.
If the above is not true, you will have to replace the icemaker.
Mar 01, 2010 | Refrigerators
Ice maker only will give crushed ice. Pressing cubes changes the light but still get crushed ice.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 19, 2009 | Frigidare FED300E Electric Range
We just bought a new frigidare refrigerator with a new icemaker installed its been a week and keep dumping the cubes..terrible taste really no smell though.. any suggestions?
Do not use a metal braided line or a vinyl braided line. Get the plastic ice maker tubing and that will fix it. I learned the hard way and now ice taste great.
Jun 22, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Nov 19, 2007 | Refrigerators
Refrigerators Logo
390 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
