Question about Ryobi Garden
My blower will not run with the choke open or at full throttle. It will run half throttle with the choke partially closed.
boscia
  • 163 Answers
SOURCE: mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Posted on Nov 29, 2008
  • 68 Answers
SOURCE: blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Posted on Dec 11, 2008
lemmingleejn
  • 173 Answers
SOURCE: Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Posted on Aug 01, 2009
  • 59 Answers
SOURCE: Blower only runs with full
it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Posted on Mar 14, 2011
vincob
  • 718 Answers
SOURCE: I have a Weedeater fl
Simple solution your weed-eater has a Walbro carb buy a rebuild kit and rebuild the carb and it will run like new, don't touch any screw settings on the carb. You can purchase from your local repair center just give them the number on your carb and they will give you the correct kit. Go to smalleng.com they have a video on just this issue. Good Luck.. Don't forget thumbs and feedback.
Posted on Apr 03, 2011
I HAVE A TROY BUIT SNOW BLOWER WITH A HUAYI CARB . IT WILL RUN ONLY AT HALF CHOKE .I HAVE CARB APART . CAN NOT GET FUEL METTERING JET OUT IAM SURE IT SCREWS OUT. HOW DO I GET IT OUT?
Why do you need to remove the jet
You can & should be blowing brakleen
& air thru all the holes
The fact you need the choke partially closed-- tells you something
Your creating higher air velocity,so check for a vacuum leak
(failed gasket) on intake side
May have a failed head gasket also
Nov 15, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
95 suzuki 250 quad king, at full throttle it runs at half power, choke seems inop
First make sure your choke circuit is working. May be an indication that your carb needs to be cleaned. I wouldn't replace it yet= clean it. If the choke circuits and the carb check out fine. An unresponsive motor/ carb usually means bad valves or valve timing. Example: it runs rich, spits fuel out the carb no matter how lean you set it. Even with the idle air closed it runs rich... intake valve is not closing or closing late. In that case it needs valves serviced.
Aug 26, 2014 | Motorcycles
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
Leaf blower runs on half choke
My craftsman leaf blower ran great for 4 years.. It stop running on me one day while using it.. I replace the carb, muffler and fuel filter with a new one.. it still will only run when the choke is half closed and don't run good doing that.. I have also noticed oil around the plug and muffler. I have to use either to get it started and I noticed when I pour a little oil in the spark plug hole before cranking it seems to run loner but not at full throttle think it might be piston rings shot.
Nov 11, 2013 | Craftsman 25cc Gas Blower
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 | Garden
Will not operate with choke full open
It sounds more like the high speed jet needs to be opened. No engine will run with the choke on. Open it up, find the little screw labeled high or fast, you have 2, one low or slow, If opening it up doesn't work, try closing it, turn it a very little bit at a time to see what it does. Hope this helps.
May 12, 2010 | Garden
Shindaiwa Blower - when throttle pushed, engine sounds flooded and it dies. any thoughts on how to fix?
Its not flooded- its lean.
Heres a way to test me. Try to give it throttle but keep it running. At the same time slowly close the choke. does it run better as you close the choke? Does it run pretty good on half choke?
Rebuild the carb, replace the fuel lines and fuel filter.
Dec 20, 2009 | Garden
Blower wont run at full throttle
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Garden Logo
398 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
