Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
My dishwasher is almost brand new and it doesn't do a very good job at cleaning the dishes. There are usually stuff stuck on the glasses on the top shelf. I've tried cleaning it by taking all of the stuff out of the centre but it doesn't seem to help. I've also tried changing to the vinegar jet dry and that seemed to help but I'm still having the problem. I thought that maybe it was just a cheap dishwasher but I'm told that it is actually a decent brand.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 14, 2010
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishwasher not cleaning dishes
Aug 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Aug 22, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Glasses do not get cleaned
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 18, 2009 | Maytag Dishwashers
Food is being shot into the top rack and getting stuck inside the glasses. It is a brand new dishwasher-had it for a week. We have tried different settings on the dishwasher and different detergents
It sounds like you have a great deal of water pressure which a plumber may be able to address.
Otherwise, This may sound simplistic but it may be easier to hand rinse the dishes that have a lot of food still on them before they are placed into the dishwasher.
Good luck. :)
Apr 26, 2009 | Dishwashers
Dishes are not clean.. on top level the dishes seem to be steamy
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
6. Smoky film on dishes and glasses
Jan 30, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Bits of food on glasses
I have the same problem, and sometimes, when I add salt to my water softener, the problem goes away until the next time I need to add salt. Other times, I have no idea when I'm going to have the crud in the glasses. I've tried different detergents, rinse agents and even different shaped glasses. Seems the glasses which have slightly larger bottoms than tops are worse.
Sep 02, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
53 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
