Question about Maytag MER5775Q Electric Kitchen Range
Oven heats to 165 - Maytag MER5775Q Electric Kitchen Range
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 14, 2010
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Aug 09, 2015 | Toaster Ovens
Ge dryer way too hot. I have cleaned all the lint out but still way too hot. unplugged vent hose and ran machine still too hot. Took apart machine and tested continuity of heating element and its fine....
I do not know your definition of "way too hot". Remove the exhaust vent and insert a accurate thermometer in the dryer exhaust. Run the dryer on high heat. The temperature should get up to 165 degrees then cool down to about 125 degrees then back up to 165.
If it goes above 165 and stays there replace the high limit thermostat.
If it cycles correctly it is OK.
Aug 31, 2011 | GE DWSR405EBWW Electric Dryer
Inconsistant oven temperature
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 25, 2010 | Ovens
Oven won't heat. Replaced the element, but still won't heat.
Which element..?? there are 3... Check for voltage to the bake element.!!! (2 legs of 110-120 VAC) Does your broil function work.? Convection.? or did "bake" flake out.? the relay boards are not very robust in these ovens, and manufactured as cheaply as possible. The board mounted relays develop cracks in their soldered connection to the PCB over time, resulting in intermittent opens for some of the relays. Spend some time narrowing down the relay controlling the circuit that is dropping out, and re-solder the node. Sometimes just hitting it with a soldering pencil will be enough to restore the connection, but I would recommend adding a little silver solder to the puddle. It will help keep that connection from opening again.! Heck, while you're at it, re-solder all the board side relay nodes to prevent future issues.. or just replace the $165 board.. :)
Dec 12, 2009 | Amana AOCS3040 Electric Single Oven
Range will default to 165 degrees
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Dec 07, 2009 | Kitchen Ranges
Oven does not heat to proper temperature. Starts at 165 F when before it started at 100 F. Bottom element goes out during warmup.
your temp sensor or oven control board is bad. Temp sensor should have around 1080 Ohm resistance in room temperature.
Oct 13, 2009 | Kitchen Ranges
I have LG dishwasher model LD 14AW1 I get error the message HE about 15 minutes into the wash cycle then the dishwasher turns its self off
HE refers to HEATER ERROR
The water is not heated
or the temperature in
the Tub is overheated
to over 95¡
Possible causes
¥ The Circuit of Heater is troubled.
¥ The Thermistor is troubled.
¥ The Heater is shorted.
¥ The Relay Circuit is troubled.
Possible solutions
¥ Repair the Circuit of Heater.
¥ Replace the Thermistor.
¥ Replace the Heater.
¥ Repair the Relay Circuit..
Feb 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Jgr8855bds range - oven problem
that's too long, check to see if you have flame in the broiler section, i'm thinking not. see if your ignitor is just staying on without igniting burner, ignitors will produce that much heat in that amount of time. if no flame at butner, replace ignitor.
Mar 31, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
96 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
