Question about Lowrance X52 Sonar Fishfinder Without Transducer
My x-52 unit will not turn on. I have returned the unit for a new one at rhe cost of a hundred or so dollars, and have the same results. I have checked for voltage at the connector, and have 12v. Not sure what to do next. If I didn't spend more money I would get a newer unit.
  • 8 more comments
  • stdnarb Sep 14, 2010
    I have the unit directly connected to the battery with proper polarity, and the unit does not power up.
    I called the lowrance service line and thats what they said it would cost. So you think I have another bad unit? what will happen if I disconnectg the transducer from the unit and try to power it up?
    I removed the fuse to eliminate possible issues no help
    Could the connector pins be dirty and not making good contact.
    Thats my next move, unless you have better idea
    If that is the case the factory sent me, sold me a dead head unit and I'll return it or get my money back, the second unit never did work.
    my x-52 unit will not turn on, it was out of warranty, I sent it back and got another unit at the cost of a hundred dollars, the new unit has the same problem, I checked for voltage at the connector, 12v. I have the unit directly connected to the battery, proper polarity, what next?
    I did check the female connect for the voltage and had 12v, maybe the male plug is not clean enough to make good contact, kind of grabbing at straws. I do not want to have to return unit again.
    I have the unit connected directly to the battery, red , black -,
    Should I disconnect the transducer and see if it powers up
    I want to rule out all possible problems before I look into returning the unit again. It seems odd that I would have two bad units doing the same thing.
  • 2,272 Answers
Yes it can be another bad unit.But two at a time is bit rare,but its possible.Still before returning the unit i advise getting ,----- disconnect the transducer and see if it powers up.If not then yes there is a internal problem in the unit.The circuit board in the unit which functions is not working and causing this,As you have tested 12volt to connector so the problem is in the unit.
Thanks. Keep updated.
Posted on Sep 14, 2010
  • 2,299 Answers
Have you checked your ground? You have to have a good ground. When you checked for your 12 volts did you go to the ground in the plug to the fishfinder? Grounds are really tricky on boats. You almost need to run a ground from the battery to the unit. I hope that this helps you out! If not, just comment back and I will try to help more!
  • Rodney Clark
    Rodney Clark Sep 14, 2010
    I would say yes. You have another bad unit. The transducer could be pulling it down. But not very likely. If you have it hooked directly to the battery and it still don't come on then there is really no other explanation.
  • Rodney Clark
    Sure, you can disconnect the transducer. It for sure won't hurt anything. But I really don't think it is going to help. All the transducer is, is a resistor. And should not in any way cause the unit not to turn on. But yes. For sure try it. I have seen stranger things!
  • 2,926 Answers
The power wires are red and black. The white wire is not used unless you are connecting a speaker, leave this one disconnected.
With the unit's power cord connected to the display, connect the red wire to the positive lead of the battery and connect the black to the negative lead of the battery. DO NOT connect the unit to a 12 volt wire, connect it straight to a battery and power it up. Does the unit power up?
  • 4 more comments
  • GetMeOttaHere Sep 14, 2010
    Ok, then you either have a defective ubit or possibly a bad internal fuse. It seems odd that the first one did not work and now the second one doesn't work. I can understand the first, but two is out of the ordinary. Why did you have to spend a hundred dollars for the exchange?
    Do you have a highly recommended 3 amp fuse between the battery connection and the unit installed?
    Nothing will happen if you connect the unit without the transducer connected. it will display a message telling you so, that is if the head unit powers up.
    You have a dead head unit and there is not much that can be done. You can try to remove the cover and inspect the inside for a possible solder connection break or internal blown fuse, but at this point, the power supply is as simple as it gets.
    Check the connector end with an ohm meter. One side positive on the connector ( I believe the connector is green that attached to the unit) and one side negative on the leads. See if you get readings or place the meter to give an audible sound that will alert of a good connection. I was assuming the connector was ruled out based on some of the details given. By all means, check the connector.
    I guess you can't use an ohm meter to verify the connection? Hummmmmm, then replace the connector. Electrical diagnostics is an art in itself, an ohm test is as easy as it gets.
My craftsman riding lawn mower won't move
Trans is shot. They cost around $600 to 1000 new. You can probably find one used for a couple hundred dollars. There are no rebuild kits for them. (Assuming this is not a zero turn) zero turns you can easily double the price....for each of the two drive units
Aug 27, 2016 | Cars & Trucks
I don't know the name of the song but I think part of it goes like this : "hundred dolla by hundred dolla" or some thing like that. Anybody know the name of it
LANA DEL REY LYRICS
Play the Lana Del Rey Quiz "Hundred Dollar Bill"
(Twenty of 'em wrapped up tight in silk)
Hundred dollar bill, hundred dollar bill
Nothing more gorgeous than a hundred dollar bill
Jimmy pulls up in his blue Chevy Nova
I have been dying for him to come over
I'm in my party dress
He say, you such a mess
I am the New Jersey Dance Queen
He is the Gangster Action King
He knows that I be selling the body
My man the best
'Cause he knows what's up
He knows it's a big bad world
Knows that I'm a good girl
He understands the sale of self
('Cause cash comes quick when looks can kill)
(Eh ah)
J. is a romantic roller coaster
He don't do anything he supposed to
I like 'em tough and mean
Jim is the worst that I've ever seen
I am the trailer park darling
He is the one-time come-back king
He knows that I be
Looking to die
He says baby pay
Respect to the high
knows that I'm a good girl
'Cause cash comes quick when looks can (kill)
Eh yeah yay
Eh yeah ah
Ah ah ah
Yay yeah ah
I like your ultra-violent swing
I like it when you treat me mean
You turn my mood from black to blue, woo
(Yeah ah yay)
(Twenty of 'em wrapped up tight in)
(Yeah ah yay)
(I need your love, I need your love ah)
(I need your love, I need your love....yeah)
(Oh, oh, whoo)
(Oooo oo oo oo)
(Ehhah yiyayeah.)
May 02, 2015 | Audio Players & Recorders
Internal error display
I had the same problem (though the unit may still work even in this Internal error state, except the tuner - try it) and my technician friend advised me to replace the HDMI I/O Card inside the unit. However the card cost is more than a hundred dollars while another brand new unit only costs around USD170 in ebay. That gave me a better option to buy a new unit but seems this Yamaha unit is a dud which could be the reason the unit production was discontinued.
Dec 03, 2013 | Yamaha HTR-5790 Receiver
How much it's cost please ?
Digital cameras costs above several hundred dollars depending on the brand names and featuree functions. Brand names like sony, philips, panasonic, fuji, samsung digital cameras with features picture video, lenses, storages spaces cost above $500 least considering warantees, and peripheral compartment. Tripod stands, camera batteries, recording chips, carry cases, charger kits, costs differently depenign on the brands names, availability at retain and buyers choice of expensive devices prefered. Recorder camera chips at most affordable with least storage spaces starts at $49 dependign on the type of cameras to suit. camera tripods stands usually would cost depending of the size either as domestic or outdoor setup costs in above couple hundred dollars. $149. Cameras that perform on backup power sources with several hours least requiring recharging are couple hundred dollars and above dependign on the extensive lastings capacity of battery supply at assigments. Consult with an electronic store retailers expert to ascertain the available sale prices. For example, the types of retail stores predict the prices avilable for each device at purchase. for example, products acquired from luxurous retailers requrie guarantee, warrantee acquisition also to make the experince acheievable. Usually more expensive camera devices have more expensive warantee costs at purchase. For example, buying a camera that cost $500 as base price after store taxes of 8% sums much differently. Warrantee may usually become couple hundred, where &149 dollars for basic warantee to several hundred dollars to full extensive years of warantees arragment with either the retails store or manufacturer.
Feb 06, 2011 | DXG Technology DXG-572V Digital Camera
Where is the fuel pump?how can i put it out?
if you are asking where the fuel pump is its in the gas tank and it must be put up on racks to drop the gas tank and remove it they cost around 2 to 3 hundred dollars for a new one and they usually cost around 1 hundred to 1 hundred fifty dollars to replace. hope this helped
Jan 02, 2011 | 1997 Jeep Grand Cherokee
MY CAR NEEDS A NEW AXLE AND 4 BRAND NEW TIRES. I WOULD LIKE TO KNOW THE ESTIMATION OF HOW MUCH IT WILL COST TO GET IT FIXED?
At a shop your looking at roughly $60 - $100 dollars a tire mounted and balanced. The drive axle will run you a couple hundred dollars for labor and a couple hundred for the part.
So total you would be in the $500 - $800 dollar range depending on the quality of the tires, the shop you choose, and the shops labor rate.
Oct 05, 2010 | 2001 Kia Optima
I NEED MS EXCEL CONVERT FORMULA FOR NUMBER TO CURRENCY
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
Summary
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
1. Click the Function Wizard button, and select User Defined under Function Category.
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
To Create the Sample Functions
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' Convert MyNumber to a string, trimming extra spaces.
MyNumber = Trim(Str(MyNumber))
' Find decimal place.
DecimalPlace = InStr(MyNumber, ".")
' If we find decimal place...
If DecimalPlace > 0 Then
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
End If
Count = 1
Do While MyNumber <> ""
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
' Remove last 3 converted digits from MyNumber.
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
Else
MyNumber = ""
End If
Count = Count + 1
Loop
' Clean up dollars.
Select Case Dollars
Case ""
Dollars = "No Dollars"
Case "One"
Dollars = "One Dollar"
Case Else
Dollars = Dollars & " Dollars"
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
Dim Result As String
' Exit if there is nothing to convert.
If Val(MyNumber) = 0 Then Exit Function
' Append leading zeros to number.
MyNumber = Right("000" & MyNumber, 3)
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & ConvertTens(Mid(MyNumber, 2))
Else
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
Else
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
Apr 15, 2010 | Broderbund Learn MS Windows XP and Excel...
Trying to find prices on a computer for our 2003 chevy suburban.
Pricey...new? Several hundred dollars; used, even at a junkyard, at least a hundred bucks. And you have to be sure you get the exact one. Write down all the numbers on the labels on the ECM you are replacing to compare against the replacement unit.
I would be absolutely certain this is what was needed before I changed it: there's no returns/refunds on electrical parts, even used ones.
Feb 17, 2010 | 2003 Chevrolet Suburban 1500
Kenmore Oven will not shut off
ok, due to the age of this unit, the repair will be costly. the issue here is a damaged control board. the control will run a little over 200 dollars and that without the labor charge. standard labor charges will vary form 50 to 75 dollars an hour and , there is a 2 hour standard start charge automatically leaved once the repair man arrives. this will bring your repair bill to the 300 dollar mark. you may be able to find a cheap repairman but, the price will be hovering in the 230 to 290 range a t best.
It would be more cost affective to purchase a new unit with a new warranty as well.
May 26, 2009 | Kenmore Ovens
Lowrance X52 Sonar Fishfinder Without Transducer Logo
143 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
