Question about Whirlpool LEQ9858P Electric Dryer
Dryer not turning on. Breaker has not tripped. We always just set the timer and push the button, no problem. All of a sudden is dosen't turn on now. I have power to the unit or at least the drum light works. Let me know Dave Millison
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 14, 2010
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Dryer wont run
I am going to try this one with very little information. First I would check the circuit breakers and make sure the cicruitg breaker did not trip. then I would turn the timer to different settings like and example delicates, normal cycle. if none of those did not work, I would look at the door interlock switch. on the door there is usually a little tab protuding out and it goes into a slot and pushes a switch. these is so the dryer will not run unless the door is closed.
so more than likely it is power loss problem
door interlock
timer/ start button
hope this helps
rick
Jul 15, 2011 | Maytag Dryers
Dryer not heating and timer does not move from set time
Try resetting your breaker. Turn it FULLY off, push to the off position firmly or you may not be able to reset one breaker, that may have tripped.
Oct 10, 2010 | Kenmore 62622 Electric Dryer
The dryer just stopped working> It's about 4 years old. Working one minute and not the next. no clicking sound when you turn the timer dial. Could it be bad dial?
Not usually a dial problem. First make sure your breaker is not tripped. If the dryer was working fine and suddenly nothing works its usually a power problem. The other problem to check is the door switch. If its not the breaker/fuse panel let me know.
Aug 19, 2010 | KitchenAid KGYS850LT Gas Dryer
My house has a T1033A which controls the bathroom fans. There is no display and even when I turn the unit to the off position, I cannot switch the fans on. Is the unit shot? I can't determint which breaker...
Open following link to identify timer and download manual:
http://waterheatertimer.org/Aube-timers.html
The reset button is small round button and can be pushed with toothpick or paper clip.
If reset doesn't restore timer, then timer is probably shot.
Also check all breakers to make sure one isn't tripped.
To test which breaker controls timer, open up box so you can test wires, and then use electrical tester and process of elimination to identify correct timer.
Add a comment and say if this is new installation or if timer suddenly stopped functioning.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jul 03, 2010 | Aube Technologies Aube 7-Day Programmable...
3 years old, totally dead dryer
remove the back panel look on the side of the heating element look for a small red button on the thermal fuse push it in.
Also look on the left side by the belt and motor you should see a black piece of plastic with small springs on it push it to the right to reset it if this has tripped,this is a saftey kill switch that gets activated by the drum belt if there if a sudden problem with the belt tension
Mar 15, 2010 | Bosch Nexxt 500 Dryer
No heat
You may need a new heating unit for your dryer, but usually and most always it's the temperature sensor that needs reset, most of them have a push button built into the sensor that you can push to reset it.
This most always works, failing that you need a new element to heat. though sometimes wires rattle loose and simply need plugged back into socket.
In all examples you need to take the panels off your unit to get the parts in question.
Hope this helps.
Jan 01, 2010 | Dryers
Dryer won't turn on. the breaker is on
Do you have a multimeter? I would suggest unplugging the unit and checking to see if there is power at the plug. If there isn't any power then I would say the breaker is defective. If you do have power, then take the back of your control panel off and check if you have power to the timer control. To double check the timer, turn to a dryer setting and see if there is power at the motor. If the meter shows power there then the motor is not working but the timer works.
May 17, 2009 | Maytag Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mine stops if it overheats and you have to let it cool down and then press a reset button on the back. It could also be fuse or it may have tripped the breaker.
Mar 27, 2008 | Dryers
Whirlpool LEQ9858P Electric Dryer Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
