Question about Panasonic Televison & Video
I changed the bulb and the television still has vertical lines across the screen and still tells me to replace the lamp.
  • 456 Answers
You need to make sure you reset the lamp use hours, vertical lines are an odd problem for a lamp replacement issue, as normally the lamp becoming faulty will result in no picture, as the lamp is the main light for the 'projected picture'.
You can obtain the lamp reset guide from the TV's manufacturer or the closest authorised repair agent and they will be able to obtain the information that you need. I hope this helps. Good luck.
Posted on Sep 14, 2010
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
Red line across the top of the screen. bulb was just replaced
HELLO,
IF YOU HAVE A SOLID RED LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I HOPE THIS WILL HELP OUT IN RECTIFYING THE FAULT AND DO TAKE CARE IN SOLVING THE PROBLEM , BECAUSE THE TELEVISION CONTAINS HIGH VOLTAGE....
May 13, 2011 | Televison & Video
No picture but sound, a few color vertical lines
there is a few things this could be - the 'vertical' of the television went out, the CCFL bulbs are on their way out/burnt out, or the inverter powering the bulbs went out. If you can hold a flashlight to the screen and see picture, it is either the inverter or the lamps - if not, then it's the vertical, and it's easier to just replace
Dec 08, 2009 | Samsung Televison & Video
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
RCA DLP/HDTV Vertical Lines
This is djb1 who commented above on the vertical lines that have gotten progessively worse. I may have found a potential solution. I unplugged the TV, took the back door off where you replace the lamp, took the lamp out, changed our vacuum from a vacuum to a powerful blower and blew ALL visable dust off anywhere that I could. I paid special attention to the heavy dust that was on the TV blower fan blades and around the mirror. I also held the blower on the outside of the TV on the vents around the lamp door.
After I plugged the TV back in, the lines have disappeared. We watched TV last night for about 2 more hours and the vertical lines never came back. So far this morning, the lines have not come back and it has been a couple hours as well.
It's worth a try. The free solution may be as simple as clearing out all dust. LET'S HOPE IT'S A PERMANENT SOLUTION!!
Dec 19, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
