Question about Mtd 22" Yard Machine Push Mower
I bought a brand new push mower and it chugs like it doesn't get enough gas. Is it a quick fix or a take back to store problem?
3 Suggested Answers
  • 77 Answers
SOURCE: push mower runs for 3 seconds and dies brand new mower used it 2x
If the carb mounts directly on top of the tank chances are the diaphram gasket between the carb ant tank has swelled and needs replaced
Posted on Aug 09, 2009
SOURCE: Lawn mower chugging
better late than never, I have the same mower
there is no throttle control on these mowers, if you look under the air filter the throttle is balanced by a spring pulling in one direction and a lever controlled by engine speed. if the spring breaks or falls off the lever will wiggle back and forth, more gas if the engine slows, less if it speeds up. you end up going fast/slow/fast/slow etc.
The tension spring slows the switching down and smooths out the engine speed.
Posted on Jul 08, 2011
Snow blower starts than it dies out I changed the spark plug new gas don't know whats the problem
I suspect the carburetor needs cleaning. Gas nowadays is terrible on equipment that sits for long periods of time (like a snow blower) without being used. The gas nowadays goes stale very quickly and gums up the carburetor. To prevent these issues use a gas stabilizer. I have stabilizer in all my jerry cans of gas. That way everything I fill up is ready to be stored at any time.
I'll give you an example of how bad the gas is.... My neighbour bought a new lawn mower. Selling feature of the mower was "guaranteed to start first or second pull". The next year it wasn't starting properly so he took it back. He was told he didn't store the mower properly over the winter (He didn't use a gas stabilizer) so no warranty. Took the carb apart and cleaned it ran like a champ....
Jan 29, 2016 | Toro Power Clear 621 R
I just bought he 550 pushmower
check for water in gas check to see if gas cap hole is clogged up when it does it check for spark at plug make sure it is sparking if not replace coil but i would tack it back to dealer tell him whates its doing tell him to fix it it warrantied one year on motor
Aug 30, 2014 | Poulan Garden
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Gas Blowing Out of Exhaust
Hi Haley
Here are a few suggestions
May 02, 2013 | Cub Cadet Garden
I have a Ryobi 6.5 push mower brand new. It worked fine for bout an 45min then ran out of gas. I put more gas in it and it has not turned on since. I've tried everything...do you have any suggestions
If your mower is that new, then take it back where you bought it from and have if fixed or ask them what you may be doing wrong to cause the issue. It's under warranty. Hope this helps. Good luck.
Jun 28, 2011 | Garden
Just bought a new Jenn-Air grill and cant get the temp past 250. Any ideas what i am doing wrong?
First, check that all the gas lines and flame bars are clear of any 'things' or bugs. I had a similar problem with a Webber grill and found out my problem was with the gas bottle. The new Overflow Protection Valve required on LP bottles can closed off or severly slow the flow of gas when the bottle is full and the valve is opened quickly. It will let enough gas flow to light the grill but won't let the fire get high enough to heat the grill up. Turn all the valves off on the grill and gas bottle. Open the gas bottle valve slowly then turn on the grill burner and try lighting it. If the flame is still very low try again or you have to let it burn at the low level until the OPV float drops down and the valve doesn't impede the gas flow. The best way to avoid this in the future is to not fill the gas bottle to the top when you have it refilled. Just ask the LP attendent to not fill it all the way.
Jun 06, 2011 | Garden
I bought a John Deere 7.0 Ft-Lbs 22"
its under warranty. let them fix it
Feb 25, 2018 | John Deere Garden
New lawn boy mower pull cord will not pull. Worked first 2x
Did you check the oil before you ran it. They usually come dry and you have to but oil in before running. Sounds like motor might be blown.
Aug 14, 2009 | Garden
Lawn mower chugging
Jul 11, 2009 | Mtd 22" Yard Machine Push Mower
1991 Cadillac Brougham not getting gas
The fuel pump is located on the frame undrneath the passenger side rear door.If you have the throtle body injection used on the 305 engine the electric fuel pump puts out about 8 psi.
Sounds like you have a clogged fuel pump. Not that bad to change if you have the special tool needed to remove the fuel lines to the pump. Ask your local Auto parts store for help.
Apr 07, 2009 | 1991 Cadillac Brougham
Mtd 22" Yard Machine Push Mower Logo
47 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
