Question about Makita 9553NB 4" Angle Grinder
My grinder is making a arching sound and i can smell burning is this the brushes?
  • 43,501 Answers
Yes, that is usually the brushes, they need to be replaced...
heatman101
Posted on Sep 14, 2010
Is there a fuse or circuit braker in a sunline SM-G31 grinder?
Hate to say it but I fear the windings have burnt and is in need of repair. Any burning smell or smell of heating is most of the time directly related to armature or burnt brushes. If this grinder suits your needs having it rewound would be profitable.
Mar 26, 2016 | Vacuums
Bosch angle grinder
Replace capacitor, Yes it would give those symptoms
Feb 03, 2015 | Bosch Saws
How can i replacethe carbon brushes on my angle grinder as they are totally and completely worn off
Buy the new brushes from the manufacturer. You already have the old ones out - put the new ones in the same way you took the old ones out.
Jul 27, 2014 | Makita 9005B 5" Electric Angle Grinder
My angle grinder has overheated and stoped. Will it go again when it cools
probably not, I would check the brushes and while the brushes are out look at the commutator thru the brush tubes, when it overheated did you smell something burning? if so you might have a electrical problem or did you hear something squealing then it might be bearings or gears. It depends on the situation but this tool doesn't have a thermal overload that will reset.
Aug 26, 2011 | Makita 9553NB 4" Angle Grinder
Makita ga9000 9 inch grinder just stoppe working no burn smell or noise could it be bushes or something more
First check to make sure the outlet you plugged into has power. (You may have tripped a
GFI elsewhere). The next possible problem is either buildup on the brushes and
commutator shaft or in the switch assembly itself. (I have this problem on one of my
grinders due to dust in the switch assembly).
Mar 03, 2011 | Makita GA9020 Angle Grinder
Is a grinder worth repairing when you can smell the motor? what parts would you expect to have to replace?
If the only part that's causing the burning smell is the brushes, yes it's worth fixing.
If it's overheating because the bearings are bad, yes it's worth fixing.
If the armature and/or field is overheated and damaged then you're better off getting a new one.
Nov 22, 2010 | Dewalt D28112 Heavy Duty 4 - 1/2" Small...
Slow,smell burned
Sounds like your brushes are used up. Take the brush caps off on each side of the grinder handle, if the carbon is 1/8" long or shorter they have to be replaced. (Makita Part #191938-1) If you overworked the tool (put too much pressure on while grinding) it's possible the armature and/or field overheated and burned out. They are Makita Part #517301-4 and #521621-0 respectively. You need a growler to check these items to see if they're shorted out.
Aug 21, 2010 | Makita Angle Grinder 4.5" 9524NBX
I have this grinder, when i plug it in and turn it on it starts smoking and has an electrical burning smell. Is this the brushes going out? and it doesnt seem like it is going full speed. Is there a fix...
Brushes usually won't start smoking on power up. Sounds like shorted windings. I would recommend a new unit rather than risking a fire. I would also recommend a professional brand if it is something you will be using a lot. In the long run it will save you money.
Jun 13, 2010 | Craftsman Professional 26437 75 amp 10000...
Just replaced the brushes in a Metabo WE14-150Quick Angle grinder
when you replaced the brushes did you notice the tool throwing sparks? Generally when I work on these after replacing the brushes I have to clean the commutator to seat the new set. You could also have other problems, e.g. bad brush holder (did you replace as assembly or just brush) Let me know what happened to the first set and if when you plug in and try it does it come up to full speed.
Sep 12, 2009 | Metabo WE14-150 Quick Angle Grinder
Makita 9553NB 4" Angle Grinder Logo
156 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
