Question about Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
I have a paslode gas framing gun when i want to nail something it makes all the sound but does not fire gas cell is good battery is good
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I changed the gas cylinder in my paslode framing nailer and now it won't fire the nails at all. The battery is fully charged and the whirring sound and smell of gas is evidenced but no nails are fired.
Make sure you have the correct gas cylinder. There are more than one type of cylinders for these nailers. If it is not correct it won't seat and gas will leak. Whiring sound is normal, fan mixing oxygen. Make sure "O" ring is in place under the gas cylinder.
Oct 01, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Jul 27, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi Logo
381 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
