Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
Have a duple qcm202-53 fireplace heater how do i access the fireplace to replace the heater in the fireplace. heater not working
My problem is I have a electric fireplace the insert is a colemen and the heater stoped I bought it a Costco about 4 years ago
It may need repairing, do not take risks trying to fix it without an expert. But its 4 years old so its better to replace it with new.
Dec 15, 2013 | Leisure HOMEPRIDE Electric Fireplace...
The fireplace blower does not work therefore there is no or very little heat from my dimplex elect fireplace---thanks
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Feb 06, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My electric fireplace don't work,I replaced the electric swith but still wont work,gas comes,I noticed that it does not make the noise while turning on that it use to make before.
I took the fireplace's direct connect ignition spark box out of the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Nov 23, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Dimplex Electric Heater Model Number DF 3003 fan motor not working. How do I access the fan motor to repair or replace it?
Dimplex has a Service Manual for your Heater. I recommend requesting the manual through their Literature Request website. I located the owner's manual and the troubleshooting guide via their website, but it appears you will need to request the Service Manual.
Hope this helps.
Mar 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Electric fireplace still works, except the flame does not light up anymore? Is there a way to fix this? It is a Chauffe-Air, Model# 6901740100 Cat.No. DFB4047 Mod. Level: MOD A Serial # 26806D6F 093. I...
Find an access door on the back or side or both.
check lightbulbs.
Do not replace with anything but exact bulb.
try taking the bulb to Lowes...I've gotten luck there before with odd bulbs...they have a special drawer for them.
Good luck,
Vinnie
Mar 21, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Oct 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
My Heater stopped working on my HEF33 Electric fireplace. My fireplace is only 3 years old not sure what to do.
We have had this same problem with our heater. But I went online to find out where I could purchase replacement parts. The company that sold the fireplace went out of business. I also went on-line to try and fine a universal replacement part. So far no help to be found.
Nov 18, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
120 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tim Whalen
Mack Baxter
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
