Question about GE Dryers
When dryer is running, there is a VERY loud squeeling. I am thinking it needs a new belt but I cant find where the belt is located. Any help would be greatly appreciated. Thank you! Shannon
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The belt is right inside the back cover on the back of the drum...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 14, 2010
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Maks loud squeeling noise when first turned on then quiets down after a few minutes of running
drum rollers/glides, belt is wearing or idler arm is wearing:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 04, 2011 | Frigidaire FGR231A Gas Dryer
At start up I have a loud squeal on my 99 Mazda 626. Both belts are new and so is the alternator. The squeal only last for about 10 secs or so and goes away. I have started it in neutral and the squeal is...
Does your car have air conditioning.? Most cars use the A/C compressor to dry the air for the defrost. It will also come on for a short time when you first start the car. With the engine running after the squeel has stopped , try turning the A/C on , If the squeel starts again , then I would think your A/C compressor is seized. Also . are you sure the 2 new belts are tight enough?
Feb 20, 2011 | 1999 Mazda 626
Squeeling while drying
worn belt, needs replacing
Oct 07, 2009 | Dryers
A/C quit blowing cold air after a loud squeeling noise stopped!
Look way down on the engine front area passenger side for the compressor.
Is the belt gone?
Check the belt tensioner pulley....can you turn it?....is it seized?
If it is OK then try and turn the compressor.......and the idler part of the compressor.
If the compressor is seized.....why?
Usually lack of oil in the system,or an overcharged system.
Once you have removed the 134a gas from the A/C system before removing the compressor and before installing the new compressor make sure you add the correct amount and type of oil into the system to prevent another seized compressor after you have flushed the system to remove contaminates such as old compressor grindings......if the compressor was seized.
You will also need a new receiver/dryer once you open the system to the moisture in the air.
Do not expose the new receiver/dryer to air....install last.
Vacuum the system well before refilling with the correct amount of 134a.
At 70 to 80 degrees outside temp........a vent temp at medium fan speed of 48 to 45 degrees should be a full charge .......use this reading if you do not have a electronic scale and/or A/C machine.
DO NOT OVERFILL THE SYSTEM.
Sep 08, 2009 | 2000 Chevrolet Silverado
Squeeking / squeeling from Candy cc2 17 smart dryer
hi,well if its not the belt,there should be two rollers in front of drum at bottom,they are wearing out or need oiled.as for getting to motor and belt,well not sure of model,but most of dryers,you will have to take front off of dryer,then remove belt the tumbler.you should be able to reach tension,and release it to get slack in belt. hope this helps. duane.
May 28, 2009 | Candy CDV262 Dryer
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Engine noise on area of pulleys and sometimes engine tries to sto
Don't know if this helps. Had squeel in belt area. Occasionally engine would stop when squeel got loud and sometimes engine would try to quit while going at various speeds. Found tensioner pulley was bad and changed it. Still squeeled and engine would stop when squeel got loud. This time while sitting in yard. Further checking found binding in power steering pump. Will be putting on new one tomorrow. Hope it works. Will update.
Nov 28, 2008 | 2004 Ford Freestar
Dryer is making a loud squeeling noise when running
This is probably the drive belt slipping on the drum or motor. There is usually no adjustment on these and it is a case of replacing the belt. If you take the top off the machine, you may be able to look inside while it is running (KEEP CLEAR OF THE ELECTRICS AND DO NOT DELVE INSIDE WHILE THE MACHINE IS IN THIS STATE!) and see the belt slipping. If it is, it's probably time for a new belt
Nov 20, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
32 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
