Question about Car Audio & Video
I have a bazooka bass tube just got new harness from them but no wiring diagram it is ELA-HP/AWK, FOR AN TMS8A-HP-S...HELP?
  • 9 Answers
SOURCE: what up with my subwoofer?
Sometimes the Bazooka tubes have an internal amp. I am not sure of this model but maybe you can Splice in directly to the Speaker Wire and bypass the AMP in the Tube if it has one
Posted on Feb 17, 2007
jmeyer847
  • 204 Answers
SOURCE: installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Posted on Nov 21, 2008
  • 50 Answers
SOURCE: need wire diagram to hook up trailer lights, truck not factory equipped w/harness,
I'm assuming you're just going to splice into the tail light wiring so that's what these wire colors are:
at the tail lamp 3 way connector:
black and yellow = park lamp
dark green and brown = left turn signal
there should be another connector with violet and black wire for reverse lights.
the stop lights are turned on through the turn signal circuits.
Posted on Apr 12, 2009
  • 74 Answers
SOURCE: Bazooka BTA series self-amplified tube subwoofer wont' power on
the blue wire is called the remote wire will go to back of head unit also to a bule wire that will send 2 amps to turn on the speaker only when the head unite is on
Posted on Apr 18, 2009
motor1258
  • 6674 Answers
SOURCE: I removed my stereo from my 2005 Chevrolet Tahoe.
Check out this link. Should have necessary info for you.
http://www.the12volt.com/
Posted on Feb 25, 2011
Omega bass tube wire diagram
I lost the conector for omega sub bazooka how i can find replacemnet
Jul 30, 2011 | Car Audio & Video
Hello the bazooka power wont come on
So it is a powered tube, yes? Can't remember, does the Bazooka have a fuse on it? If it is powered, you blew the board.
Apr 07, 2010 | Bazooka BTA8200 Car Subwoofer
Subs stop producing sound when stero volume is turned up
make sure your wiring is correct.. negative to negative positive to positive.
Oct 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
Bazooka auto amp
remote wire is the blue wire maybe has white stripe that runs into stereo run from there to remote on amp as far as bass knob remote its common 1/4 stereo jack or a phono plug (looks like a phone jack)
Apr 19, 2009 | Bazooka ELA500.1 Car Audio Amplifier
Apr 18, 2009 | Infinity BASSLINK Car Subwoofer
ELA 500.I
While I don't have any first-hand experience with either Bazooka amps or Memphis subs, this review pretty much says what I initial thoughts were. The amp will do the job without much fuss, so it mainly depends on whether you can get it for a good price.
BUT........
There could be a issue with your sub. According to Memphis, your sub (assuming it's the single voice coil version) is only good for about 250W RMS (let's ignore peak power for now). The ELA500.1, on the other hand, puts out 375W RMS at 4 ohms. You could very easily overpower your sub with that amp.
Mar 13, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
Nov 07, 2007 | Bazooka MBTA8200 Marine BT Series 200-watt...
NO SUB OUTPUT
The sub outputs are simply lowpass filtered preamp outputs for use with a subwoofer amplifier. They supply a lowpass filtered signal for a subamp or 'powered subwoofer" like a bazooka tube. Test your "basstube" for 12 volt input power and make sure the "sub" setting on the radio is turned up too.
Aug 26, 2007 | Sony XPlod CD Player w/MP3 Playback...
What up with my subwoofer?
Feb 06, 2007 | Bazooka BT6014 Car Subwoofer
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
