Question about Kenmore Dishwashers
No matter what cycle the dishwasher runs, the glasses always have stuff stuck to them. have run a couple of different washer cleaners through it but no luck .heating elements are fine. any suggestions
  • 5,081 Answers
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Posted on Sep 14, 2010
No matter what brand of rinse aid I use, there's always a white film on glassware, dishes, etc. Is there something wrong with the dishwasher?What could be the problem?
Hello, W/D here.
We've had the same problem, and here's what we did to solve it.
Clean the dishwasher as best as possible. Place t cups of vinegar in the bottom of the tub, and run a hot cycle. The vinegar helps kill and remove the scum that can build up in the sump of the tub. If the spray arms are clogged, you can remove the debris with a paperclip or toothpick. (Check and do that regularly anyway).
Cut back on the detergent as far as you can, while still getting the dishes clean. I know this sounds a bit odd, but the amount of recommended soap is based on the dirtiest dishes, and the worst water possible. We rinse the major food particles off of our dishes before loading, so dried on food stuffs isn't an issue. We have cut our detergent to about 25% of the recommended amount, and the dishes still get very clean. We put a sprinkle on the door, a sprinkle in the dispenser cup, and close it up.
The detergent itself is abrasive, and can leave deposits on the dishes, most noticeably on the glassware. Cutting the amount of detergent, and using a good drying agent helps a lot.
Over a period of several cycles, the quality of the wash will improve. Don't expect to get to 25% of the amount of detergent right away. Cut it to 50% to start with, and adjust the amount based on your own observations.
Hope that this helped you. Best regards, --W/D--
Feb 10, 2011 | Frigidaire FGHD2433K 24 in Builtin...
Soap does not all desolve during wash cycle, there is always some left in the door. we use cascade. this dish washer is new and we have always had this problem.
this could be caused by hard water depending on where you live. Make sure you always use Jet Dry, run the hot water on your kitchen faucet for a few minutes before you start the dishwasher and if that doesnt work there are a few different dishwasher cleaning products out there. This one works good: http://www.finishdishwashing.com/product-finish-jet-dry-dishwasher-cleaner.php.
Nov 10, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
I have used dishwasher cleaners, use Cascade Complete dishwahing detergent but all of the sudden, my dishes come out of the dishwasher dirtier then they went in. The glass glasses have a gritty stuff...
depending were you live they changed the formula in cascade,but they are doin a new formula are you using a rinse agent? claean the machine clean spray arms and soap dispencer,with no dishes run machine with 1cup of CLR or 2Cup of vinegar just pour in tub and let it run full cycle no drying.Thanks
Jul 31, 2010 | Whirlpool Dishwashers
Doesn't clean properly, Leaves dry residue in washer
My dishwasher had the same problem. glasses were cloudy, inside the dishwasher was coated with a film, drawers were hard to pull out. tried rinse agents and vinegar and nothing worked. Found lemi-shine at WalMart (it's next to the dishwasher detergent) and the white stuff is gone! no more residue and glasses sparkle again. I was ready to buy a new dishwasher I was so frustrated. get some - it's amazing! a couple bucks and it's back to normal. I was SOOOO happy!
May 21, 2010 | Siemens 24 in. SL84A305UC Built-in...
Calcium (white) buildup on wiring in bottom of my Whirlpool dishwasher...how can I remove this?
There a few good products to clean this. Purchase one of the following, you can find them at the store near the dishwasher detergents. I am listing in order of my preference. Follow the instructions on the package, but basically run a cycle with no dishes and the cleaner. A home remedy that works but not as well is to put a bowl of vinegar upright in the lower rack. Run through a normal cycle and the vinegar will wash out and clean the calcium away. You may need to do this a couple times.
- Lemi Shine
- Finish dishwasher cleaner
- Glisten
- Glass Magic
Apr 30, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Cloudy glasses My dishes are not being cleaned. There is a white residue on my glasses and in the dishwasher itself.
You may have hard water. Are you using a rinse aid, you always need to use one. Buy some Tang drink crystals and empty a package into the soap dispenser and run the dishwasher through empty. If you can't buy Tang use about 4-6 cups of white vinegar thrown in the bottom of the machine and run the cycle. Sometimes the white residue on the glasses is there permanently and can't be removed it is called "etching" right in the glass.
Jan 26, 2010 | Kenmore Elite 45986 Front Load Washer
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 | Dishwashers
Dwu7400aax - dishes do not come clean eough
make sure you water is hot enough, manufactures reccommened 120 degrees to the dishwasher, i advise all customers to run hot water at sink til you get hot water then turn dishwasher on, also fill both compartments of sopa, also use rinse aid or jet dry, do not use gel packets. use cascade powder or liquid only.also run the unit through a clean cycle this should be done once or twice a year. letdishwasher fill with hot water. when starts to wash, open door and add 2 cups of white distiilled vinegar and close door and let it go throughas cycle. no dishes. also i reccommened dish majic cleaner sold at walmart or grocery stores. if this dont help then youw wash syatem could be bad or going bad.hope this helps you. try all these things first befor you re[lace uniy or pay to have it looked at.
Sep 17, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Aug 22, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Particle residue on glasses in top basket for glasses at the corners
The oldest dishwasher I have replaced was a Kithcenaid installed in 1953. It was a 24" built in with a smaller door, a handle looked like it was for a safe, and it had an s-trap underneath. The 90 year old customer said it did the same thing. My advice is to run a dishwasher cleaner through a hot cycle according to manufacturers directions. Check the holes in the spray arms carefully for any debris. Our service guys advise not to use gel or liquid type soap as it leaves a tiny residue after each load which will eventually clog your internal plumbing. Always use the least amount of soap you can get away with and POWDER is prefered.
Apr 24, 2009 | Dishwashers
Dishwashers Logo
75 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
