Question about Kenmore Washing Machines
Kenmore Series 80 Washing Machine agitator and drum will not turn. Any ideas on what the cause might be? (I have the cover removed, and everything looks in order.)
  • Kenmore Master
  • 3,361 Answers
Could be a bad lid switch.
Could be a bad drive coupling.
Could be a bad clutch.
We need a model number to narrow it down.
Posted on Sep 14, 2010
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series does not agitate.
Hello, Welcome to FixYa.
The model and serial number tag will be under the lid at the back of the "lip/shroud" as you look from the front.
Based on your description, the problem is likely worn agitator dogs/gears. The new dogs alone part # 80040 or what I'd recommend, part # 285751 as a kit with new hub too. These are common and availble at most brick & mortar parts depot's as well as on-line vendor's.
You`ll need to remove the top of the agitator to replace them.
To remove the top cover of the agitator, it should lift off by prying up gently with a flat screwdriver or puddy knife.
Under this cap there actually is a screw/fastener,( bolt ) it just may or may not look anything like a typical screw. It could be a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it, I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose. It may be the bolt style and in that case just remove the bolt and lift it out.
On Kenmore full size washer`s built by whirlpool there are one 2 types, ones with a 7/16" bolt holding it in place, and the type I described.
Thank`s for visiting FixYa. Good luck and let me know if I can assist you further.
macmarkus :)
Jul 15, 2010 | Kenmore Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
drum is stationary in wash and moves only in spin
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Sears Kenmore 80 series washing machine Model 110.26832691
How do you remove the top of a kenmore washing machine? I have a mouse stuck in the lid and can not get the top off.
May 24, 2008 | Kenmore 24032\24036 Top Load Washer
you removed the cover ??? cool your looking right at the pump assy remove the 2 clips and release the pump from the motor assy(dont remove the clamps) thers enough room to hold it of to the side, after doin this try starting the machine(it should at least agitate with cover removed.)if it does agitate with no problem stop the machine and reinstall the pump(you may have to manually turn motor shft to correctly align pump. try it again.if it doesnt work now then theres something stuck in the pump(baby sock, bra underwire).
Feb 24, 2008 | Washing Machines
Washing machine
This sounds like the brakes have gotten some residue on them and are grabbing way too hard. The banging is the tub stopping too fast and the torque from this makes the tub bang into the cabinet. Just one bang at the end of a spin. Is this correct???
Nov 25, 2007 | Kenmore 23012 Top Load Washer
Washing Machines Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
