Question about Maytag Refrigerators
When the unit is plugged in there is a buzzing sound by the compressor for a few seconds then a click sound.After about a minute it does the same thing does not cool at all.
  • Maytag Master
  • 3,361 Answers
You have to replace the compressor start relay and capacitor.
Posted on Sep 14, 2010
Whirlpool ed25dq Not Cooling
Unplug unit from the wall, remover the start relay from the compressor and shake it. If its solid possible bad compressor, if it sounds loose (broken part) then most likely bad relay. Verify your model number as you are missing some letters.
Good Luck
Dec 13, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MSD2351HEB sidebyside occasionaly goe thru frequent cycling buzz. Last for a couple of seconds, then repeats a few minutes later. sounds like a solenoid click when going off.
if this model has the techumse compressor it is probably drawing high amperage and kicking out. the click and buzz is the compressor winding stressing to draw the energy needed. compressor maybe bad. the compressor model usually starts with a t11...
Aug 01, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
The ice is melting in my Amana arb2205.It clicks,buzzes for a few
sounds like a bad compressor relay. The compressor it self might be bad but 80% chance it is just the relay.
Oct 23, 2009 | Amana ARB2205C Bottom Freezer Refrigerator
The freezer has stopped working and now the fridge is warming up! Seems to be coming from the bottom of the unit - it makes a buzzing noise followed by a click, as if it is trying to fill something...
Is the compressor (underneath the refrigerator) not running?
If so, the buzzing sounds like the compressor is trying to come on, and it won't for some reason. That's major repairs.
Oct 15, 2009 | Refrigerators
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
My refrigerator buzzes for 5 or so seconds then
the buzzing noise your hearing is possibly your compressor trying to start up. this is generally a buzzing for 5-7 seconds followed usually by a click noise if it goes on for several hours you will notice the temps in the unit starting to rise. for alot of may tags with the tecumseh compressor the compressor had to be replaced. if it has an embraco compressor you can just replace the start relay on the compressor. let me know what you find thanks Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Noisy compressor
If it's a buzzing for a few seconds followed by a click, your probably going to need a compressor. This sounds like that problem. Check your warranty. Many manufacturers went to 1 year on this in '06.
Nov 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
