Question about Electrical Supplies
The generator worked great untile it got low on oil and shut down. the oil was changed but the engine wouldn't start without unhooking the oil saftey switch, the engine runs great but it wont put out anything. i have checked to see if i could see anything burnt or blown and cant find anything,i dont know how to check that winding in the generator could you tell me how or what you think my problem is, i smell something in the outlet box that smells burn but cant see anything wrong
  • 61 Answers
If your engine is running after unhooking the oil safety switch then reconnect it while the engine is running keep it running for another ten minutes for the oil alert senser in the engine to start working again make sure the oil has been topped up according to the specifications then stop the engine the oil warning lamp will not come again.
Posted on Aug 12, 2012
  • 5,807 Answers
I am sorry for what happened to your generator.
It needs an engine Repair ( mechanical )
not electrical anymore.
You will need to bring it , or have someone to
rebuilt your engine, Your electrical components
can be checked later after the engine is running.
Consult your dealer for more details on servicing.
It would have been better to run out of fuel ,
than run out of Oil ( from the manual )
Posted on Sep 14, 2010
  • 1 more comment
  • Rommel Cana
    Rommel Cana Sep 14, 2010
    But if the engine is running , you might need
    or someone to help you check for
    Circuit Breaker, Coils Inside
  • Rommel Cana
    there could also be thermal sensor or switch or fuse
    here is a basic
    Troubleshooting
    for coil and fuses
  • Rommel Cana
    Never check continuity when Engine is running.
    But if you need to post voltages on the output of the generator
    you might need to have it started.
    Besides the coil , it also have Carbon Brushes
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
UNIT SHUTS DOWN FREQUENTLY
How soon after starting does it shut down?
The hour meter is fed directly from the AC output off the generator stator, if there is no AC output the meter will not run. Assuming it shutdowns quickly, check 1st the oil level and make sure the low oil sender unit is ok, wire #24 to ground. If that is bad it will shut down. Check to see if you have 240V on L1 and L2 on the breaker for the brief time it does start, that will confirm stator/rotor has an output, then your problem moves from the generator portion to either the oil sender, or control board.
Feb 24, 2013 | Powermate Coleman Standby Generator...
I have a centurion 3250 watt portable generator it was working fine 2 days ago but it will not start. Will not being on a level and flat surface cause it to not run ?
Hi and welcome to FixYa, I am Kelly.
Your question:
"Will not being on a level and flat surface cause it to not run?
In short YES!
Generators have low oil level sensors that are quite fussy about their orientation. If there are any inclinds a generator is sitting on you can get FALSE low oil level shut downs.
You must make sure the generator is full of oil and I do mean FULL. Additionally do what you have to so that the generator sits level horizontally.
A quick way to find out if the low oil level sensor has been activated is to simply check spark.
If you have no spark:
FILL WITH OIL
Re-orient generator to a level position (15 to 30 second wait)
(Check spark again) If you now have spark your low oil level sensor had gounded the ignition because it sensed a low oil level either from an actual low oil level condition or the unit was on an incline causing a false low oil level senor activation and a subsequent engine shut down.
Thanks for choosing FixYa,
Kelly
Aug 28, 2011 | Electrical Supplies
I have a new Guardian 40G generator that won't start (correctly, anyway). When I squirt gas into the intake it runs until that is gone then dies. The fuel pump is pumping gas to the carb. but it seems to...
Try to measure the voltage at the connector when trying to start.
If it is 12 V and the engine does not start - disconnect it and try again.
Have in mind that you must have protections (Shut down):
  1. Low oil level;
  2. Low oil pressure;
  3. High temperature.
and this valve may be responsible for them.
Jun 20, 2010 | Guardian Rv Generator 4800 Watt, Gasoline,...
I have a proforce 2500 watt generator and it cuts out is this caused by low oil? if I change oil how much does it get?
Low oil doesn't usually make engines cut out. Clean the air filter, change the plug and wire. If this doesn't help then I think you're looking at a carb. problem. Probably just clogged jets & ports. It's very common on small engine carbs. It shouldn't take more than 2 quarts of oil. Probably not even one.
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Will start wont stay running over minute and cant find a manuel
Most likely your carb. is gummed up. Drain out any old gas [over one month old] and replace with new. Change the spark plugs. And, add a carbeurator cleaner [ from any autoparts store]. Then start it up and let it run, restart it and let it run, restart it and let it run until it will run for as long as you want it to.
Nov 13, 2009 | Electrical Supplies
Generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Sep 20, 2008 | Electrical Supplies
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
