Question about Dishwashers
Dish drawer leaks Fisher Paykel
My Fisher & Paykel Double Dish Washer is leaking water from the front on the
left side. Their is an F1 Error code. Without killing the power to the unit it does not stop running. Currently both the power and the water are shut off. Looking
for help. Thanks Wayne
  • 1 more comment
  • spoonz May 18, 2008
    I have exactly the same fault, Did you find a solution?
    Thanks
  • Anonymous Mar 16, 2014
    u3 error fisher paykel dish drawer
  • Anonymous Mar 23, 2014
    Will not start when turned on and water connected and turned on
When water accumulates in the bottom it triggers an error code and it keeps running. There is a water sensor in the bottom. I pull out the bottom drawer, mop up the water and use a hair dryer to dry the water (the more you mop up the less you need the hair dryer). Be careful to not get any of the plastic too hot. Kill the power before messing with the unit. The first time I did this it took 20 minutes to dry out. I have gotten more proficient and it take about 5 minutes now.
I had a water leak which was due to the rinse agent cap not being completely sealed. Water leaked out of a small hole in the front (I'm guessing an air vent but don't know for sure) and flooded the bottom.
I also had a leak due to having too tall a dish in the drawer and the top not sealing. I currently have a leak on the top drawer of unknown origin, but the bottom drawer still works.
Hope this helps.
Posted on Jul 10, 2008
2 Suggested Answers
  • 145 Answers
SOURCE: dish drawer leaks
The f1 is a flood error. There is a sensor in the bottom reading water. You have to dry it out before you can do anything or the drain pump will just keep running. Check the lid of the drawer you where using to see if anything may have been holding it up or if the seal is torn. If that looks ok you will have to check the lid actuators to see if one is not working. I would replace both right and left if one is out.
Posted on May 15, 2008
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Showing f1
The f1 fault is cased by a leak on the dishwasher.
It is activated when water gets to a dangerous level in the base of the appliance near to the PCB.
The main reason this happens is putting cups on the drop down shelves and when the lid comes down to seal the drawer it can't and leaks. If you look at the drawer when open there is a lip around it, if anything is proud of this lip the lid will not shut properly.
To rectify this problem you will have to disconnect the power and remove the bottom drawer and the dry up all the water in the base. If you leave the appliance long enough it will dry out by itself.
Once you have done this and the problem still comes back you will need and engineer as there is a problem with the lid motors or the seal’s.
Good luck hope this helps..
Mar 21, 2010 | Fisher and Paykel AeroTech Double OD302...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My dish washer has a f1 code i put to much
f1 code indicates a leak.open bottom drawer,find the spring clips on side of tub where tub meets the front panel.push the clip and you will be able to slide the track back and remove tub. put tub on floor to left you should see a puddle,dry it up should be ok. Sensor is sensitive to moisture allow 24 hrs to reset if all visible water has been dried up. hope this helps ,please rate my solution :)
Jun 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer leaks
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Dishwashers Logo
2,212 people viewed this question
Top Dishwashers Experts
