Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
I have a mp250 cannon printer that wont let me feed any paper into it just makes a clicking noise but doesn't print.
  • 86 Answers
SOURCE: printer will not feed paper / message E2 ...cannon pixma mp 160
If you hear the printer trying to grab the paper (you also may see that the rollers turn) but it does not grab the paper , means the the rubber that grabs the paper are dryied, and should be replaced.
If the rollers do not turn (no sound either) then there is a problem with printer's mainboard.
Meanwhile (if you need it urgently) put more pages in tray to add volume (will press the paper to the rubber).
Posted on May 08, 2008
SOURCE: mp600 pixma printer
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Posted on Sep 07, 2008
Arius
  • 446 Answers
SOURCE: samsung clp-300 Paper feed problem.
there must be an obstruction in the paper path, pls see underneath the printer platform or inside your printer
cheers
Posted on Nov 25, 2008
SOURCE: Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Posted on Apr 22, 2009
thbestofme
  • 64 Answers
SOURCE: printer wont feed paper through to print on
there are a lot of steps that u need to follow.. I tried to get the detailed link but it didnt seem to work properly.. so try this link below.. http://tinyurl.com/2kdp28 once on this page.. go to support & service.. and search for FEED PAPER... and select the second answer there.. and follow steps there.. let me know if this was helpful to u.. regards, guru
Posted on May 05, 2010
Paper wont feed
Could be a piece of paper stuck somewhere, open all access areas and check carefully, sounds like an obstruction somewhere
Apr 01, 2014 | Cannon i70 Printer
I have refilled the cartridge of my printer but It doesn't prints anything on the paper what should I do??
make sure that u loaded the cartridge correctly if not installed correctly it wont print next make sure that u reset the printer, unplug for a couple of mins
Apr 25, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
My paper will no longer feed through the printer while printing. It still acts like it is printing **** the paper does not feed through. How do i fix this?
Try this > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences' or 'Properties'
- In the next window click 'maintenance'
- do all the cleaning process
- this will fix the problem.
hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nov 02, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code P03. It won't print, it doesn't make any noise when I turn it on, and I don't see any traces of paper.
Error code PO3 is caused by Timing Disk dirty / damaged.
Please use this methods
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
And start to print... thanks
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper feeding through printer but not printing
hi! if that printer doesn't print at all,since it was configured by your computer,try to check it's properties to test the function of your printer.doing this go to control panel click printer,then right click printer,click properties.on properties click test your printer,if this printer, print but nothing appear on paper,back to your properties and go to maintenance,on maitenance click clean printer,on try deep cleaning if still doesn't print bring your printer to cannon service center to check the printer head. regards and thank's
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Mar 11, 2009 | Canon Office Equipment & Supplies
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
264 people viewed this question
old marine
old marine
