Question about Sentry Fireproof Safe
Handle came loose and wont open safe. I have the handle off and now need to know how to move inside part to open latch.
3 Suggested Answers
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
2000 vw passat door latch
Sounds like something came loose on inside of door. People who lock there keys in thier car always try to unlock the doors with coat hangers and all kinds of stuff. Sometimes it knocks the clips loose inside the door and causes handle to not open door. Sometime they just wear out. I believe your going to have to take the inside door panel off to fix it..
Aug 18, 2013 | Cars & Trucks
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
My 91 chevy truck is stuck open
SOUNDS LIKE LATCH WAS IN CLOSED POSITION WHEN DOOR WAS SHUT I'VE HAD IT HAPPEN A FEW TIMES PUT A SCREWDRIVER IN THE LATCH OPENING AND PRY WHILE PULLING INSIDE HANDLE...IT MAKE TAKE A TIME OR TWO
Oct 11, 2012 | Chevrolet Cars & Trucks
Handle on outside turns but tail gate will not open on A 99 ford expadition eddie baura
lower tail gate then remove tailgate access cover either handle broken or look inside tail gate for latch rods that the handle moves latch rod either damaged or look for loose or missing latch rods nuts.
Sep 17, 2012 | 2000 Mercedes-Benz M-Class
Rear pontiac grand am door stuck
I have a 2002 pontiac grand am with both power windows and door locks. Everything else works except the lock assembly on the rear driver side rear door latch. I have removed the inside panel , aboth rods are connected. all power is disconnected to that door. I moved both of the rods correctly and the door will slightly open but that is all. How can I get it to release so I can repair or replace the latch and lock if nescessary ? I had the same problem only reversed with the frond door it would not close but after some trying I fixed that problem.
Apr 04, 2012 | Pontiac Grand Am Cars & Trucks
Have a 1998 Jimmy, the driver door is stuck in the close position and can not close the door. The handle seems to be working properly; inside handle moves the cable that permits the door to close and...
with the door open see if latch is stuck in close position . If so hold handle open and pry with screwdriver to open latch ..If that works latch needs to be lubed for smooth operation
Feb 17, 2011 | 1998 GMC Jimmy
Driver side door latch closed shut with door open. Will not open to engage and allow the door to safely close.
Place a large screwdriver in the Latch (on the end of the door), and while lifting your inside or outside door handle (make sure the door's unlocked), move the screwdriver out until the hook re-opens. If this doesn't work, it sounds like the rods and plastic retainers within the door have come loose, which will entail the removing of the door panel. Should it come to that, then in moving the door openers (both inside and out), you will see which rod fell out of what and just snap it into place. Sometimes this occurs when you need assistance with keys locked in car and a "slim-jim" is used to pop the lock...the slim-jim will knock the door linkages off. If this be the case, contact the Wrecker Service that unlocked your car. For future reference, a good Wrecker driver will always go through the front right passenger door for "lock-outs."
Good Luck,
~Stillin~
"Still living on the Right Side of Dirt..."
May 18, 2010 | 2005 Honda Accord
1997 F150 Pickup door wont open
I believe there is a cable which connects the handle to the latch, they are pron to breaking.
Jun 21, 2009 | 1997 Ford F150 Regular Cab
Door won't open after self cleaning.
it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
Dec 31, 2007 | Ovens
Sentry Fireproof Safe Logo
441 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
