Question about Grindmaster 3511 Freezer
I am working on my freeze machine and can't seem to find the source of my problems. The compressor draws high amps and kicks off 1-2 seconds after start up, blowing the main circuit breaker in the process. All wiring seems to be fine besides the transformer having a loose terminal. Could that be what's causing the unit to draw excessive current? The supply voltage also drops from 115V to 77.9V when I power it up. The is a apot visible on the circuit board, indicating that it may be overheating (flux possibly sweating???). I really am out of bright ideas so if anyone can help me I would deeply appreciate it. Thanks
  • 30 Answers
Could also be a bad start or run capacitor too. Check the capacitor to see if it is out of range or open.
Posted on Dec 05, 2014
    Master:
    Sergeant:
  • 449 Answers
Your compressor motor needs to be replaced (replace the compressor)
Posted on Sep 14, 2010
I have a Frigidaire freezer LFFU1424DW not freezing. Came home to melting ice and thawed food. I heard clicking noise like a fan but goes off after a few seconds. Help please.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
Mar 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Hi - We've got a Turbo Air TGF-23F mrechandising freezer that freezes - down to -15 and then suddently begins to warm up about 1 degree per minute. In about 15 minutes its just over 0 degrees and...
Did they test the thermostat? I would think that the compressor would kick on before you got that much of a fluctuation, unless the thermostat is not sensing the change fast enough.
The run and start capactiors and relay, did they give you a reason for that? When the compressor kicks on does it surge the power? Light dim or something? It is hard to guess without being able to put an o'scope on your machine to be able to see what it is doing, but just based on what your write-up was, I can't see the parts you said they want to replace will fix the problem.
Jun 08, 2011 | Turbo Air Freezer 23 cu ft Single Glass...
The compressor only kicks in for a few seconds and switches off for a few minutes. It is hot but the freezer is not freezing
Actually, its not kicking on for a few seconds and switching off, its trying to start every few minutes. This could be caused because the compressor is bad, or the start kit which starts the compressor is bad. Since you will not have the equipment to jump start the compressor to see if the compressor is bad or the starter is bad, you will either have to have it inspected by a refrigerator repairman or buy the start kit, i.e. overload and start relay, for your model refrigerator and hope thats the problem. But if it turns out the compressor itself is bad, you will not be able to return this start kit once you install it, since any parts supplier will not accept returns on electrical parts.
Oct 26, 2010 | Freezers
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Freezer compressor not able to start and noisy.
It sounds like the compressor is locked (seized). The current overload is doing it's job by opening the circuit. Take a current reading, on the common leg, while the compressor is trying to start. The locked rotor amps (LRA) for that compressor will be indicated on the compressor tag. If it's drawing LRA while trying to start, you need a new compressor. Which is the costliest part in that unit and requires specialty tools to replace.
Mar 30, 2017 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Compressor problem
The click your hearing is a thermal cutout that is kinda like a little breaker, it gets to the temp that it is designed for and trips. If its making a high pitch noise, more than likely the compressor itself has gone out and needs to be replaced, its getting a high load and triping the thermal cutout.
Sep 21, 2007 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Grindmaster 3511 Freezer Logo
153 people viewed this question
Top Grindmaster Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Grindmaster Freezer Expert? Answer questions, earn points and help others
