Question about Farmall Tractor A-i,av,super A ,super Av Radiator
Have a farmall super c when the guy repainted it he power washer the old grease and dirt out from the fly wheel now after i start it i cant get it into gear
  • 514 Answers
Worked on a farm-all not too long ago and soundslike he may have knocked something into the yokes or knocked something loose. pull the inspection plate off the front of the trans housing and see if it is jambed or loose up in there.
Posted on Sep 14, 2010
Why would m Farmall tractor overheat
Radiator flues clogged with dirt, hose collapsing, fan belt slipping, fan blades need cleaning, radiator needs backflush, thermostat stuck, leaking head gasket or cracked head.
May 03, 2014 | Farmall Tractor M,super M,md,super Md...
Loss of tension for a kettle coach rowing machine
The fly wheel has a 'freewheel' mechanism similar to the rear wheel on a bicycle. It needs cleaning and regreasing with light grease to free it up and make it work properly. The job is not difficult but needs some diy knowledge. Before trying to remove the fly wheel some slack will need to be created on the 'bungee' return cord and anchored securely. You will also require circlip pliers to remove the shaft. The freewheel mechanism is a set of needle bearings that move forward in their recess to allow the wheel to rotate and move back and lock when the wheel rotates in the opposite direction. These need to be free moving and old grease thickens and becomes sticky. Clean with something like GT 85 and regrease with a light grease.
Dec 29, 2013 | Kettler Coach Rowing Machine
Axle makes a noises going forward only sounds like a bad bushing
there is no bushing on my rear wheels axle albeit an older scooter...wheel runs metal to metal on the axle and so...remove wheel and clean an grease the axle an replace the wheel.... probably wouldn't hurt to run a greasy rag back and forth through the wheel a time or two too...Sometime next week. The Maintenance Dude here @ Big Muddy River Apartments will be correcting a dry rear wheel on my old ole Golden Companion II. I had just acquired the thing and almost immediately after I sat on it to take it for a spin. The left rear wheel started acting up. Lucky my power chair guy does scooter repair too, and he told me no bearings in the back wheels. Its metal to metal and removing the wheel an greasing the axle should take care of it, and I havt'a say that was really admirable of him cause he could have clipped me for a service call and a grease job.....the end
Jan 15, 2011 | Golden Technologies Golden CompanioN II -...
Which cylinder is #1 on a Farmall Super C....toward the radiator or toward the steering wheel.....
The radiator. All in line engines always have the #1 cyl closest to the harmonic balancer / belt pulley.
Apr 11, 2010 | Farmall Tractor A-i,av,super A ,super Av...
2003 chevy silverado 2500 HD when ingageing 4 wheel high on the fly it makes a load clunk and grinding noise
I had a similar problem and had to have the 4 wheel drive serviced. It need new grease. the grease i had was old and it was causing the gears not engage cleanly thus causing the grinding sound until they were realigned.
Feb 10, 2010 | 2002 Chevrolet Silverado 2500HD
How hard is to install a coil in a 1950 super a farmall
The super a uses a delco distributer along with a stand alone canister coil like those used in most older mid 70 cars, so all you should need is to pick up one from a junk yard or go to TSC and pick up a new one
Nov 20, 2009 | Farmall Tractor A-i,av,super A ,super Av...
Working on farmall super a tractor distributer had been pulled so trying to reinstall but can't find timing marks
Remove valve cover,bring #1 cylinder top dead center,make sure both push rods are loose,put you dist in and were ever your rotor is pointed that will be your number one wire.then you will have to adjust you timing when started by ear,I hope this helps you
Sep 09, 2009 | Farmall Tractor A-i,av,super A ,super Av...
Farmall Tractor A-i,av,super A ,super Av Radiator Logo
164 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
