Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
I cannot get the alarm to stop beeping! The freezer has had constant problems, and it is having a problem now, but it is 8pm and I cannot get a service person here. How do I override the alarm?!
  • 3,083 Answers
First off, let me direct you to a neat site that will have parts diagrams, parts lists, and shows exploded views, helpful for identifying switches and other things that can signal the control board to go in to alarm:
http://www.appliancepartspros.com
Enter your model number, since the one provided just gave me washing machines.
To get the beeping to stop, you have to fix or bypass the problem. You mentioned constant problems with the unit, so I'm thinking you might have a bad door sensor switch, etc, or a bad control board, or both.
Ok, in the following blog they had replaced a control board and that didn't fix it. Here's what they said, and how another person diabled the piezso buzzer:
ok at the top of fridge is a grey cover that covers the wires that are attached to the fridge make sure that little button is pushed in when the doors are closed..
#9 Victor commented on Nov. 19th, 2007 at 9:29 a.m.:
Just cut the wires on the Piezzo Buzzer, it looks like a little circle, or put a piece of tape on it, this will stop this really annoying beep, you need to have some Electical Knowledge though, sure some one you know can do it.
The switch could be brolen, also, and hopefully the diagrams will help you.
Here is the blog with all the people who had this problem and how some fixed it:
http://www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
The door switch sounds like the most likely prospect. Make sure the unit is perfectly level, that can effect how the doors sit and seat.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 14, 2010
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Jan 12, 2016 | Refrigerators
Fridgidaire freezer stop beeping
Good Heather, thank you for your inquiry! If the temperature of food rises to an unsafe level, the buzzer/beeping will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Jul 22, 2013 | Frigidaire Gallery 24.6 Cu. Ft. Chest...
How to stop alarm of freezer
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
Apr 18, 2012 | Freezers
Alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Mar 01, 2010 | Liebherr Refrigerators
My GE upright freezer constantly beeps!
It sounds like this is a a non DIY issue. there is really not much you personally can do.
Contact an authorized servicer fir best results
Dec 13, 2017 | GE Freezers
My intergrated Beko fridge freezer keeps beeping. I have defrosted it but it still keeps beeping! Please help this driving me wild!
Tell me, what is the purpose of that beeping. There should be some indication. Lots of different alarms come up. Most common are when the evaporator fan does not transfer frost to the rest of the the fridge. So check fan for movement.
Sep 11, 2009 | Freezers
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Alarm
The door alarm beeps constantly on my GE Prof Arct. The filter light is blinking when it beeps, but I do not have it hooked up to water. Is there anything I can do to stop it?
Aug 22, 2008 | GE J Series 18.2 cu. ft. Top Freezer...
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
166 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
