Question about Ovens
WE USED THE SELF CLEANING FEATURE AND NOW THE OVEN WILL NOT HEAT UP.PRIOR TO CLEANING EYERYTHING WORKED FIND.
  • Ovens Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 14, 2010
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
Tip
Before you choose to run you oven in the “Self Clean” mode be sure to read this.
After viewing many hundreds of range and oven problems there is one constant theme that comes through. “After running the self clean feature” on my oven I have this problem or that problem. Whether the oven is gas or electric does not seem to matter. The common thing is that the self cleaning feature was just used on the oven, and now it is not working, the glass broke, or you now, cannot even get the door open.
The basic idea of a self cleaning oven is to get the oven so hot that you incinerate everything that is in the oven. The heat from this process will burn up everything in the oven and sometimes things outside also. Even though the wiring and controls are built to withstand high heat, taking the oven to such high temperatures pushes everything to the limit. If something is not insulated perfectly or has shifted a bit then the heat causes it to fail. Repeated heating also wears the insulation out and causes it to break down. For this reason the self cleaning features should be used sparingly.
Manufacturers want to please the customer so even though they know that this can create problems they also know that this feature sells more products. It is in your best interest to not even use this feature if possible.
If you have a oven that will not unlock after the cycle you have a few things you can try.
First make sure that you wait long enough before you try to open the oven. If it has not cooled completely it will not open. Do not run a clean cycle when you do not have the time to let it cool completely before you need it. Sometimes if you cycle the power to your oven off and then on again you can reset the oven and it will open. Turn off the breaker to your oven for a good minute or two before reapplying the power again.
If this fails to work then check your manual for instructions or to get a factory service number. They should be able to give you the information you need to open your oven.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Jan 25, 2010 | Ovens
Do i have to take out the oven racks before I self clean the oven?
If you don't take them out the high heats can wreck the finish on them and turn them all kinds of crazy colors.... but if you don't care what they look like after the cleaning you can let them in...
My recommendation is to not use the self cleaning feature...
It is more like a self destruct feature.... it causes many problems with ovens and ranges from the high heat...
heatman101
Apr 21, 2011 | Frigidaire Ovens
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Jan 17, 2011 | KitchenAid Ovens
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
After using self cleaning function my oven had no power. Replaced the thermal relay and it worked fine. Now, we have run the self cleaning function once more and the oven died again. Is there another...
There is always going to be a problem whe you run your self clean feature. Your oven heats to over 800 degrees and this high heat takes out electronic parts.
Oct 18, 2009 | Whirlpool RBS245PDS Electric Single Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Ovens Logo
48 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
