Question about Roper RAB2121KW Top Load Washer
Washer will not fill all the way.
On the large load setting the washer will only fill half way and then begin washing. On a small load setting it fills a quarter of the way.
  • 481 Answers
You may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
Posted on Jun 27, 2008
I have a maytag top loading washer. the washer if set to medium load or large or super large load only fills to the half full level,
My maytag has a rubber tube that goes from the bowl up to the level sensor. I would try removing this tube and blowing it out to make sure that it is clear and not perished.
May 26, 2015 | Maytag Washing Machines
My washer filled up with water during regular beginning cycle and once fill washer just stopped. I feel like this happened before and it was something that may have gotten stuck in the drain??.....I move...
Hello LazyOne
The motor is locked out until the water level requirement is met. The level selector switch is probabably having issues, try rotating it back and forth between small / medium / large loads. If it starts to fill on larger load sizes, it will be the switch itself. If it doesn't do anything at all, it could be the switch, but most likely it is the level sensor. Both are located in the compartment behind the controls panel.
Sep 10, 2010 | Kenmore Washing Machines
Wash starts before water is full
most washers if put on a large load do start going around before the water has finished filling this is just to get all the clothes fully wet before the proper cycle starts to wash them it is just how the washer copes with a large load peter
Nov 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
Washer over fills with water
There is a pressure switch with a long thin hose or tube attached to it. It is inside the washer and can be located with the back or the top removed. As the water fills, the pressure in the hose increases and the switch activates at a determined pressure, shutting of the water valve. I have seen bad switches and pinched or clogged hoses..
Jan 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Roper RAB2121KW Top Load Washer Logo
324 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
