Question about E-Machines eMachines Desktop PC
On start up I get error message Unsupported Mode on my screen
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
Login into safe mode and change the refersh rate from desktop properties
Posted on Sep 14, 2010
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Says unsupported mode.. what do i do to fix it
Mode unsupported error message usually appears when having problem sending a fax to a specific fax machine. Here's a link to the Lexmark website to guide you on what to do. http://bit.ly/alsndu. Follow the instructions carefully. Hope this helps. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jun 27, 2010 | Lexmark X4270 All-In-One InkJet Printer
Unsupported Video Configuration Detected
Apparently you set a video resolution which your monitor isn't able to handle. Try booting in safe mode by holding the F8 key at boot, then change resolution to something safe such as 1024x768. Reboot in normal mode and set the resolution you're most comfortable with.
Oct 29, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Wrong cartridge 093-982 cyan toner unsupported
are you using a dell-branded toner cartridge? if yes, then you should replace the toner cartridge sensor and machine control unit (MCU). if no, you can enable the non-dell toner mode on your printer's operator panel. how? press menu, down until "configure" & press select; down until "maintenance" & press select; down until "non-dell toner" & press select; down until "on" & press select.
Aug 12, 2009 | Dell 3000cn Laser Printer
Unsupported video signal
It is possible that Jewelquest changes the screen resolution to one that is not supported by the TV. I am not familiar with Jewelquest, but the typical reason for the unsupported message is a resolution outside of the supported range. The supported resolutions should be listed in the owner's manual. Dan
Jun 12, 2009 | Toshiba REGZA 47HL167 TV
Unsupported Format error message
FIRST OF ALL TRY TO PLAY ORIGINAL DVD AND COMEBACK.
Dec 13, 2008 | Bose Lifestyle 18 System
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
